Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-18-2011, 05:38 PM   #1
Drywall and stucco?
I live in SoCal and am doing some remodeling. I have an add on room that has a couple of walls that are maybe 1/4 inch drywall with a 1/2 inch of stucco type material piled onto it. They are interior walls and I can't figure out why that material would be used. It is a house from the 50s but I don't know when the add on was, prior to the mid 70s at the minimum. It is a room with maybe 18 foot beams across the ceiling, would it be to strenghten the walls?
I hope not as I have already torn the drywall/stucco off. It wasn't easy and it sure is heavy.
thanks
puckhog is offline   Reply With Quote
Old 05-18-2011, 05:44 PM   #2
Framing Contractor
Drywall and stucco?
It was most likely plaster with 1/4 gypsum lath.
sixeightten is offline   Reply With Quote
Old 05-21-2011, 05:17 PM   #3
Drywall and stucco?
I agree... that was the beginning of the transition from Plaster to Drywall. I'm surprized it's only a 1/4" though.
dberladyn is offline   Reply With Quote
Tags
drywall, stucco
re-stucco job - Paint Question TampaBay Painting 6 03-29-2011 08:36 PM
Repairing stucco felt paper titan7 Building & Construction 5 02-26-2011 09:44 PM
STUCCO Question GrandSportC3 Building & Construction 0 12-12-2010 09:06 AM
Should I avoid this stucco home? daveyv General Discussion 17 09-09-2010 09:25 AM
drywall over stucco nmartinh Drywall & Plaster 4 07-08-2009 10:44 AM
