#1 |
drywall on skylight shaft walls above ceiling
i hope this question is simple enough to formulate verbally and should not require a picture but do let me know if you'd find one useful.
i will have a skylight (2' x 2') some 3.5' above my bathroom ceiling. everything is framed nicely already. considering that the order of hanging drywall on ceiling vs. walls is important and should be the ceiling first, i though the order might be important here as well. so, should i hang drywall first on the four walls of the shaft that rises up to the roof from the ceiling or should i hang the ceiling drywall first? thanks Last edited by amakarevic; 03-19-2012 at 09:07 PM. |
#2 |
Framing Contractor
It doesn't really matter. When I used to hang, we liked to do those skylight shafts when it was cooler. You don't want to be in there on a sunny warm day.
| The Following User Says Thank You to sixeightten For This Useful Post: | amakarevic (03-19-2012) |
#3 |
so it is OK to make the ceiling DW cutout flush with the shaft box framing and then have the shaft sheet go over it to form the edge, correct?
#4 |
Framing Contractor
drywall on skylight shaft walls above ceiling |
#5 |
thanks much, sir
#6 |
Drywall contractor
Totally agree with sixeightten. Skylights like yours (I like to call them "light tunnels") get hung in the coolest part of the day. As a rule, ceilings are (almost) always hung first. Walls, including skylight walls are hung last...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops. |
| Tags |
skylight ![]() |
| Display Modes | |
| Plaster walls with a new drywall ceiling | Johnstrant | Drywall & Plaster | 2 | 03-05-2012 08:23 PM |
| hanging ceiling drywall in a basement | charlie bob | Building & Construction | 4 | 03-11-2011 10:49 PM |
| Installing Drywall Ceiling | daytrepper | Drywall & Plaster | 10 | 02-10-2011 01:52 AM |
| Replacing drywall ceiling only, not walls | shan1616 | Drywall & Plaster | 10 | 11-15-2009 04:15 PM |
| finishing a drywall ceiling | mmhendrie | Building & Construction | 12 | 03-17-2009 10:11 AM |
