Drywall Sheets Didn't Meet On A Stud - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-11-2013, 07:18 PM   #16
Rewards Points: 242
Unfortunately I can't remove the sheet and reinstall as the stairs are already there. Ill cut it back to the studs and reinstall a piece. Thanks for all the info!
Lemkie is offline   Reply With Quote
Old 08-11-2013, 07:44 PM   #17
Rewards Points: 6,652
Rock is cheap, and yes you can remove it and redo. Always go horizontal on Drywall, never vertical.
Old 08-15-2013, 12:16 AM   #18
Rewards Points: 2,212
If you can move the one sheet say 5/8" out past the other then rip a strip of 1/2" ply say 3-4" wide and slip it in behind, screw both sheets to this and Bob is your uncle.
mae-ling is offline   Reply With Quote
Old 08-15-2013, 08:21 AM   #19
Rewards Points: 5,974
[QUOTE=gregzoll;1228093]Rock is cheap, and yes you can remove it and redo. Always go horizontal on Drywall, never vertical.[/QUOTE]
Not always true.
The Following User Says Thank You to ToolSeeker For This Useful Post:
digitalplumber (08-15-2013)
Old 08-16-2013, 11:47 PM   #20
Rewards Points: 4,796
Not necessarily. Consider all details and decide after weighing pros and cons.
jeffnc is offline   Reply With Quote
Framing basement exterior walls gheffron Building & Construction 7 06-08-2012 01:00 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
