Drywall Sheets Didn't Meet On A Stud - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-11-2013, 01:38 PM   #1
Rewards Points: 240
Drywall sheets didn't meet on a stud
Hey all,
As you can see in the below pictures I have two sheets of drywall that didn't meet on a stud. Long story short the stud is about 2 - 3 inches off. The result is that the end of one sheet is very flexible, which leads me to believe that the plaster will just crack if I finish the joint the way it is. This is a wall next to a set of stairs that I replaced so I don't have the option of removing the sheet and installing a stud in the proper location. The wall behind the dry wall is 2x2 studs next to my block foundation. I'd like to know what options I have here. I was thinking of maybe using tapcon screws to screw through the sheet and into the foundation, but I don't know if this will cause any moisture issues (moisture travelling down the screw and into the drywall sheet).
Any help would be much appreciated.
Thanks!
Lemkie is offline   Reply With Quote
Old 08-11-2013, 03:54 PM   #2
Rewards Points: 1,426
Cut out the piece between the two studs including 3/4 of an inch onto each stud. Slap another piece of drywall in there. Now tape and mud the two butt joints that you've created.
mikegp is offline   Reply With Quote
Old 08-11-2013, 03:56 PM   #3
You could also slide a butt board behind there if you can somewhat move the sheets around in the space available to you.
Old 08-11-2013, 03:57 PM   #4
Or, cut out a piece passed the two adjacent studs and use two butt boards. This way you'll have two recessed joints to tape and mud.
The Following User Says Thank You to mikegp For This Useful Post:
ToolSeeker (08-11-2013)
Old 08-11-2013, 05:48 PM   #5
Rewards Points: 240
Thanks for all the suggestions. I need to ask though; do you see an issue with using tapcons into the foundation? This seems to be the easier way as long as it won't cause any issues.
Old 08-11-2013, 06:05 PM   #6
DIY staff
Rewards Points: 7,174
Tapcons will not hurt a proper foundation----
Old 08-11-2013, 06:08 PM   #7
Rewards Points: 6,652
Go back and reframe in new studs at 16 or 24 on Center. Sounds like you had someone frame that wall from both directions, when it was built, is why it is all jacked up.
Old 08-11-2013, 06:08 PM   #8
Rewards Points: 240
Fair enough, however it will have to go thoug the vapour barrier and insulation. This is the part where I don't know if there will be a problem or not, or if I'll have to worry about condensation or anything?
Old 08-11-2013, 06:11 PM   #9
Rewards Points: 240
Reframing isn't really an option. Like I said the drywall is behind a set of stairs that were built in place. Reframing would mean having to rip out the stairs and rebuilding them.
Old 08-11-2013, 06:13 PM   #10
Actually it would not, if you know what you are doing. Your only choice is to reframe the studs that the drywall will be attaching to. So that means pulling all that drywall down, and redoing it properly.
Old 08-11-2013, 06:14 PM   #11
DIY staff
Just add a stud---no fancy framing is needed---it is just holding the seam together.
Slit the vapor barrier and tape it back together----
Old 08-11-2013, 06:16 PM   #12
MT Stringer's Avatar
Rewards Points: 198
How far is it between the 2 studs? If it was me, I would cut the drywall back to each stud, and if necessary, nail in a spacer to the adjoining stud. Then cut and fit a piece of drywall to close up the gap.
Summary - cut your drywall to fit the studs. Tape and float, and go have a cold drink.
Hops this helps.
Mike
MT Stringer is offline   Reply With Quote
Old 08-11-2013, 06:53 PM   #13
JOATMON
ddawg16's Avatar
Rewards Points: 798
16, the most important number in building.
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
gregzoll (08-11-2013), Gymschu (08-11-2013)
Old 08-11-2013, 07:33 PM   #14
DIY staff
You are trying to do 'stand up' sheets---you may be better off switching to horizontal sheets---
Old 08-11-2013, 07:41 PM   #15
DIY Enthusiast
sublime2's Avatar
Running concrete screws through that rock will not help.
You will never get the stability you need for that edge.
As mike suggested, remove the rock and reattach it horizontally.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
Framing basement exterior walls gheffron Building & Construction 7 06-08-2012 02:00 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 01:05 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
