Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-20-2011, 09:35 AM   #1
drywall seams splitting
help! all my corner seams are splitting. no water damage. I just built my home last spring.
absebok is offline   Reply With Quote
Old 03-20-2011, 09:54 AM   #2
Super Moderator
Pictures---and what method and materials were used,if you know.
Old 03-25-2011, 08:29 PM   #3
did you do the drywall? did you use paper drywall tape? are you refering to the angle? if so most likely there was not enough mud behind the tape. take old tape off angles and re run any tape that pulls loos around flats and such back with new mud wipe down tight. the re tape angles hope this helps. ohh by the way make sure some idiot didnt use paper adhesive tape to try to cover angles
lrobertstoner is offline   Reply With Quote
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
drywall cracking at seams in family room mayhem69 Drywall & Plaster 15 01-17-2011 08:57 PM
Bulging Drywall Seams SPB Drywall & Plaster 3 12-28-2009 05:23 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Repairing cracked drywall seams pjm Drywall & Plaster 3 03-08-2009 01:34 PM
