Drywall Seams Around Doors. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 01:50 PM   #1
Drywall seams around doors.
Hi everyone,
So, I drywalled my basement, but unfortunately I was an idiot and didnt realize I should have the drywall seams not line up with the door opening edges.
For example, I did it like Figure 2 here:
http://www.renovation-headquarters.c...l#.UWRigas4UzE
instead of Figure 3.
I know, I should have done more research first
Anyways, at this point I have finished mudding / taping, sanding 3 coats. I'm ready to paint. What should I do? Should I rip out the drywall, and redo it properly? Or should I hope for the best and continue finishing?
Thanks!
ithm is offline   Reply With Quote
Old 04-09-2013, 02:02 PM   #2
Rewards Points: 22
I'd leave it and take my chances especially since it's a basement. Is it an older home where everything has had a chance to settle?
Dan
djlandkpl is online now   Reply With Quote
Old 04-09-2013, 02:05 PM   #3
It's a new home. 3 years old.
Old 04-09-2013, 02:19 PM   #4
Rewards Points: 22
My guess would be that it's settled enough. Patching a crack that may never happen is easier than starting over. I'd leave it.
Dan
The Following User Says Thank You to djlandkpl For This Useful Post:
ithm (04-12-2013)
Old 04-09-2013, 07:16 PM   #5
Rewards Points: 626
Originally Posted by ithm View Post
Hi everyone,
Thanks!
way to much work I would just leave it and hope for the best. And that is why I also hang my sheets horizontal and not vertical. just chalk it up as good learning experience and next time do it right. Who knows you might get lucky and not have a problem?
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
ithm (04-12-2013)
Old 04-09-2013, 09:05 PM   #6
Rewards Points: 4,796
Horizontal sheets have to end somewhere too. The problem is where the drywall is cut, not in which orientation it's hung.
Horizontal vs. vertical should be decided based on the length of drywall that is available to you (or you can handle), the total length of joints, and the length of butt joints vs. tapered joints.
With 8 foot ceilings and 16 foot drywall, you can completely eliminate butt joints in most rooms hanging horizontally. With 8 foot ceilings and 8 foot drywall, you can completely eliminate butt joints by hanging vertically. For most situations you should do the math and decide.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
ithm (04-12-2013)
Old 04-09-2013, 10:08 PM   #7
Rewards Points: 6,652
That would be an older home. Most homes built these days do not even last 10 years before they start to fall apart.
Old 04-10-2013, 01:36 PM   #8
Rewards Points: 5,974
I would let it go. Yes someday it will probably crack but that may be years down the road. Enjoy your new home and don't worry about it. The worst is someday you have a crack to repair. Come back then and we'll help you repair it.
The Following User Says Thank You to ToolSeeker For This Useful Post:
ithm (04-12-2013)
Old 04-10-2013, 06:04 PM   #9
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 894
Hi everyone,
Thanks!
I wouldn't rip out the drywall. Just don't slam the door.
Seriously though, Maybe you could put one of those hydrolic door closers on that door if the door is going to be used a lot.
Sir MixAlot is offline   Reply With Quote
Old 04-10-2013, 09:48 PM   #10
If the drywall is attached properly, and the wall does not flex, like in most cheaply built tract homes, or any home these days that is put up in six months, by the lowest bid, the OP should be fine.
Old 04-10-2013, 11:05 PM   #11
Hi everyone,
Thanks!
do the the drywall again...do it perfect this time
skyroofers is offline   Reply With Quote
Old 04-12-2013, 11:29 PM   #12
automated tool pro
Rewards Points: 152
I would never make my seems vertical to save on a few feet of rock.
drywallfinisher is offline   Reply With Quote
The Following User Says Thank You to drywallfinisher For This Useful Post:
Sir MixAlot (04-13-2013)
Old 04-13-2013, 07:03 AM   #13
1, who said anything about "saving rock"?
2, what exactly is wrong with making vertical seams?
Old 04-13-2013, 07:11 AM   #14
Finisher you try to explain it everyone else has.
Old 04-13-2013, 08:25 AM   #15
Rewards Points: 894
The only time I hang drywall vertically is on commercial projects. Because it's required to be done that way for fire code.
The Following User Says Thank You to Sir MixAlot For This Useful Post:
ToolSeeker (04-13-2013)
Tags
cracking , door , drywall
drywall on oak doors ndmick Drywall & Plaster 4 01-06-2013 07:29 PM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 05:36 PM
drywall cracking at seams in family room mayhem69 Drywall & Plaster 15 01-17-2011 07:57 PM
Bulging Drywall Seams SPB Drywall & Plaster 3 12-28-2009 04:23 PM
