Drywall Seams - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-27-2013, 06:25 PM   #1
analogmusicman's Avatar
Rewards Points: 560
drywall seams
so why do you have to "tape" seams anyway? I guess maybe the seams would crack without tape?
the reason I ask is because nearly every time I tape a seam (except for seams involving 2 pieces of wallboard with tapered edges) I end up sanding the mud down to the tape. UGH! not enough mud you say? well,I'm always afraid of creating a "bump". so,what's the answer? how do the pros do such seams?
tnx,
analogmusicman is offline   Reply With Quote
Old 01-27-2013, 06:39 PM   #2
Rewards Points: 13,270
One an untapered seam it needs to be much wider. Use a up to a 12" wide knife.
Old 01-27-2013, 07:21 PM   #3
Tape adds some flexibility to the joint. When you working with butt joints you really have to build it up a little and feather it out. Can also use butt boards to taper the butts. Use a piece if ply 1x4 or so and attach something such as drywall shims to the edges. Screw the butts in and they will get sucked in just a little.
mbryan is offline   Reply With Quote
Old 01-28-2013, 01:41 AM   #4
Rewards Points: 1,092
i don't think 4" wide is enough. someone else posted a pic of homemade butt boards here, and i have duplicated them for my shop. i have just started sheetrocking, and it looks like these will work ok. 4" seems a tad narrow to get the rock to bend; maybe 1/2" would. here is the pic he posted; google "butt boards" and steal their design.
The Following User Says Thank You to jklingel For This Useful Post:
mae-ling (01-28-2013)
Old 01-28-2013, 07:18 AM   #5
Rewards Points: 5,974
Tape adds strength to the joint mud on it's own has very little strength. Butt joints are hard to hide that is why it's always recommend to use the longest piece of drywall available. As said use a 12" knife and go 12" on both sides of the joint and use thin coats, probably take at least 3 coats feathering each coat out farther till you reach the 12" on each side.
Old 01-28-2013, 10:40 AM   #6
Rewards Points: 2,210
You do not want a 'flat' joint on typical butt joints, there will be a small hump. Feather it out 12" on each side as said so it is 24" wide and just above the tape high in the center.
mae-ling is offline   Reply With Quote
Old 01-28-2013, 07:11 PM   #7
Rewards Points: 560
"butt joints" are a pain in the butt!
tnx,
Old 01-28-2013, 10:34 PM   #8
Sorry to confuse. Was meaning 1'x4' or 12"x48"...
Old 01-28-2013, 11:03 PM   #9
ah, yes. those little tick marks make a big diff! i have a couple of ?? on butt boards;new thread started.
Old 01-28-2013, 11:18 PM   #10
Yeah, minor details... Assumed as it would be s 4' seam would translate...
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
drywall cracking at seams in family room mayhem69 Drywall & Plaster 15 01-17-2011 08:57 PM
Bulging Drywall Seams SPB Drywall & Plaster 3 12-28-2009 05:23 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Repairing cracked drywall seams pjm Drywall & Plaster 3 03-08-2009 01:34 PM
