Drywall Screws Popping En Masse - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-29-2012, 07:09 AM   #16
Rewards Points: 12
Originally Posted by wkearney99 View Post
For this to happen after 25 years is a sign that something has happened to the structure. There's nothing that would just 'happen' by itself after that long to explain it. I'd look at what might have changed related to the structure and the ceiling. GBR's post about truss lift was fascinating. Might there have been something related to attic or roof above the popping ceiling?
Not that I'm aware of. But there are more popping in the bedroom that were not there even when I made the original post. What would the recommendation be? Should I hire a general contractor? This is getting ridiculous.
creoena is offline   Reply With Quote
Old 08-29-2012, 07:13 AM   #17
Rewards Points: 150
I bet if you pulled a chunk down there will be no glue underneath!
If my advise helped you hit "Thanks"
Hammer450R is offline   Reply With Quote
Old 08-29-2012, 07:14 AM   #18
Rewards Points: 12
But why would it all of a sudden happen after 25 years?
Old 08-29-2012, 07:19 AM   #19
Rewards Points: 150
You dont know that, you just moved in in May...just about the time when crappy cover up starts to show its ugly head.
Old 08-29-2012, 08:46 AM   #20
bbo
attic venting ok? maybe moisture condensing in the attic?
bbo is offline   Reply With Quote
Old 08-29-2012, 01:16 PM   #21
Drywall contractor
Rewards Points: 1,070
No glue and the screws were likely overdriven. Once the screw cuts the face paper on the rock, it's "game on" for pops. That's why I glue and NAIL on wood framing. Nails, driven properly without tearing the paper, will have fewer problems. Someone may have repaired the screws before you moved in by just re-mudding. You'll need to add screws (or nails) close to the existing ones to pull the board tight to the framing members without cutting the face paper. Your lumber should be "dried out" by now, but it will still "move" (expand/contract) during heating/cooling seasons to some extent.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
drywall + P&L screws ? Fix'n it Drywall & Plaster 3 07-26-2012 10:35 AM
Regular floor screws in pressure treated wood Fred_ Building & Construction 17 07-18-2012 08:38 AM
Drywall Damage After Wallpaper Removal katega Drywall & Plaster 1 01-28-2012 10:11 PM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 12:24 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
