Drywall Screws - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-14-2009, 11:01 PM   #1
Rewards Points: 150
drywall screws
I have a lot of fine threaded drywall screws left over from attaching drywall to RC channel.
Are fine threaded screws OK for putting up drywall onto wood studs?
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 11-14-2009, 11:51 PM   #2
Thumbs up
IMHO; There's no difference. Only the drill (or whatever device you use) is spinning more on Fine Thread screws. I'm not such a big expert on installing dry wall. Although I did some. (No matter what)Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 11-14-2009, 11:54 PM   #3
Yup, heck they still use nails in some places. However I would use a coarse thread for the ceiling
Timberratt is offline   Reply With Quote
Old 11-14-2009, 11:59 PM   #4
Thumbs up
Meaning that the coarse thread screws have a better grip? then I learned something. Presuming you're a real experienced Expert! Your name probably tells us something about your expertise. Eliminate confusion through Education!
Last edited by spark plug; 11-15-2009 at 12:00 AM. Reason: Typographical error (Typo)
Old 11-15-2009, 12:03 PM   #5
Registered User
Rewards Points: 5,516
They don't hold in wood as well a father spaced thread does. You would also void the warranty from the drywall board manufacturer if any problems ever arose: "2.2.5.1 Type G screws, for attaching gypsum panel products
to gypsum panel products; Type S screws, for attaching gypsum
panel products to light gage steel framing and wood
framing members; and Type W screws, for attaching gypsum
panel products to wood framing members, shall comply with
Standard Specification for Steel Drill Screws for the Application
of Gypsum Board, ASTM C 1002. " From: http://www.gypsum.org/pdf/GA-216-07.pdf
Be safe, Gary
Old 11-16-2009, 09:28 AM   #6
yup they hold better, I set my screws 6" on the edges and roughly 10" in the field. On the ceiling I go a bit closer. Have fun!
What's the trick to get drywall screws all the way in? cody21 Drywall & Plaster 14 08-09-2009 11:05 PM
Drywall Dimples using Screws mitaccio Drywall & Plaster 7 01-28-2009 09:13 PM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 12:26 AM
screws near drywall butt edges mike_a_davies Drywall & Plaster 2 08-22-2008 07:57 AM
Drywall screws? Fine or coarse, tip for my drill yummy mummy Building & Construction 31 09-27-2007 02:15 PM
