Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-27-2011, 05:28 PM   #1
drywall + screws
Ok 2 questions here
1. drywall a ceiling what thickness should I use, I have 16" on center furring strips installed. What size screw also
2. Drywall thickness for my walls on 16" on center 2x4 walls and size screws also.
Thanks for any input
Level is offline   Reply With Quote
Old 05-27-2011, 06:21 PM   #2
Super Moderator
drywall + screws
In most areas 1/2 inch drywall is good for ceiling and walls---1 1/4" screws.
Check local code some require 5/8" on ceilings --1 5/8" screw.
Level (05-27-2011)
Drywall Screws Rusting? rick112 Drywall & Plaster 17 03-29-2011 11:57 AM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 01:24 AM
Attach Drywall through plywood HooKooDooKu Drywall & Plaster 2 01-20-2010 11:05 PM
Large drywall patches - best way to fix? Screw them to what? Scott99999 Drywall & Plaster 6 11-19-2009 05:34 PM
