Drywall Screw Selection - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 10:48 AM   #1
I am putting drywall up over furring strips that are attached to block. The drywall will be 1/2" and the true thickness of the furring strips is 3/4" for a total thickness of 1 1/4".
I've seen that the recommened size is usually 1 1/4" #6. I'm thinking that I will need to go with a shorter screw to get the screw head just slightly recessed.
What do you guys recommend. It will be going up in a bathroom as apart of a Kerdi shower install.
Thanks.
DaveTile is offline   Reply With Quote
Old 03-31-2011, 11:17 AM   #2
the Musigician
DangerMouse's Avatar
I had the same situation and used 1" just fine.
The only problem is go SLOW and be firm but gentle setting them in or they can strip easily and you'll have to move it and try again and have another hole to patch.
DM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 09:02 AM
Drywall over Drywall.. NoviceHandyman Drywall & Plaster 6 01-10-2011 08:32 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Rookie questions - drywall paper rips Eusibius2 Drywall & Plaster 13 08-14-2010 08:46 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
