Drywall Screw Bits? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-09-2013, 12:10 PM   #16
bbo
huh? I have square drywall screws.
seems pretty easy to find if you are looking for them.
http://www.menards.com/main/building...5_facet=Square
bbo is offline   Reply With Quote
Old 10-09-2013, 05:33 PM   #17
Rewards Points: 5,974
very true
Old 10-10-2013, 11:04 AM   #18
AHH, SPANS!!!
Rewards Points: 1,166
I've found phillips screws to be the go to for up 1 1/2" long. anything longer becomes questionable on drive ability and stripped heads though the newer impact drills drive longer screws home quite well
hand drive is offline   Reply With Quote
Old 10-10-2013, 05:07 PM   #19
I see none on there that says square head except the trim head and those can't be used for drywall.
Old 10-10-2013, 06:32 PM   #20
Rewards Points: 4,784
Click on them and read - they're all square head. Look at the link address. Square drive was built into his search :-)
http://www.menards.com/main/building...184-c-8930.htm
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
ToolSeeker (10-11-2013)
Old 10-11-2013, 06:43 AM   #21
Never heard of that brand wish stores here would carry them.
Old 10-11-2013, 08:44 AM   #22
bbo
looks like lowes carries square drive drywall screws, different brand though.
Old 10-11-2013, 11:00 AM   #23
Mine does't unless they just started will check Monday.
Old 10-11-2013, 12:06 PM   #24
bbo
I feel bad for you. really, I was tired of the screw stripping the bit on londer screws so I just went to my local apron store and picked up a 5lb box of the square drive.
Old 10-11-2013, 04:57 PM   #25
You don't have to use drywall screws. These will work fine (the picture is a stock picture for all their screws - the picture shown is not a 1 1/4" screw - that's why the head looks too small.)
http://www.homedepot.com/p/Deck-Mate...6#.Ulhl6VPi1rM
Old 10-22-2013, 10:25 PM   #26
Rewards Points: 141
If you want a drywall bit that will last a long time you should be using a #2r bit not a reg #2. 2r bits are made for drywall screws. Only problem is trying to find them. They aren't to common anymore. Here is a link to them on amazon.
http://www.amazon.com/2R-PHILLIPS-DR.../dp/B002FY911S
paul100 is offline   Reply With Quote
Old 10-29-2013, 01:27 PM   #27
Dave88LX's Avatar
Rewards Points: 564
How are drywall screws built differently to necessitate a special bit? What's the difference between a #2 and #2R?
Thanks.
Dave88LX is offline   Reply With Quote
Old 10-29-2013, 04:08 PM   #28
The bit for drywall screws are a bit smaller so the tip sits in a little farther so in a drywall screw it won't strip as easy. At least this is my understanding.
The Following User Says Thank You to ToolSeeker For This Useful Post:
ddawg16 (10-29-2013)
Old 10-29-2013, 09:22 PM   #29
Rewards Points: 141
Thats my understanding also. I think the "r" in 2r means reduced.
The Following 2 Users Say Thank You to paul100 For This Useful Post:
ddawg16 (10-29-2013), ToolSeeker (10-29-2013)
Old 10-29-2013, 09:34 PM   #30
JOATMON
ddawg16's Avatar
Rewards Points: 824
Good info guys.....first I have ever heard of it.....
Now I need to find those bits...
What type of nails/screws should be used with furring strips? firsttimeremode Building & Construction 18 10-02-2012 09:30 AM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Drywall Screw Selection DaveTile Drywall & Plaster 1 03-31-2011 12:17 PM
drywall screw pop ryanh Drywall & Plaster 4 03-19-2010 09:40 PM
Drywall screw inspection requirements? epeterson777 Building & Construction 11 03-30-2009 01:29 PM
