Drywall Screw Bits? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-07-2013, 11:19 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 852
Drywall Screw Bits?
What do you guys use?
I have already gone through a pack of 5 #2 Dewalt bits and I'm only about half way through all the screwing around I need to do.
No, I don't use one of those fancy heads...I prefer to just do it by site....I've gotten pretty good at it....but it doesn't take long before the bit starts slipping on the head of the screw because of wear.
So what do you guys use? How long do they last?
Old 10-07-2013, 04:11 PM   #2
Rewards Points: 5,974
I have been using the Dewalt buy in 25 packs. The Dewalts seem to last a little longer. What ruins them is when they spin out, once 1 spins it's not long for the world.
The Following User Says Thank You to ToolSeeker For This Useful Post:
ddawg16 (10-07-2013)
Old 10-07-2013, 04:15 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 852
Ok....so it's not me? Good to know about the spin out....makes sense....
On average, how much life do you get out of them?
I sure wish the made the screws in square head....
Old 10-07-2013, 04:33 PM   #4
Rewards Points: 452
I've seen very few bits that didn't need the point ground off just a little to allow the bit webs to fully seat. Test them for wobble in a screw head before chucking or "chucking" as in the trash can.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
Old 10-07-2013, 05:30 PM   #5
Rewards Points: 12,882
Look for the ones that say Impact ready on the package. The one's I use have what looks like a serrated face on the bits.
I can easily go a whole day none stop with one bit.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
Dave88LX (10-29-2013), Gymschu (10-10-2013), ToolSeeker (10-07-2013)
Old 10-08-2013, 01:28 AM   #6
Rewards Points: 626
I just use these and one or two last the whole job. http://www.homedepot.com/p/t/2023023...1#.UlOXzjK9KSM
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
Oso954 (10-08-2013)
Old 10-08-2013, 01:31 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 852
I picked up a pack tonight....we will see how they last....
Old 10-08-2013, 02:20 AM   #8
I just go buy the true drywall tip and I have had the same tip for over a year two renos you should never wear it out because there is no such this as to much pressure with it b3cause when you push to hard the stopper with stop you from drilling anyway and I just set the torque on my drill to 7 and it never ever slips
lanny is offline   Reply With Quote
Old 10-08-2013, 07:50 AM   #9
HUH:w00t
Please put link have done drywall for a lot of years and have never heard of it, have never seen anyone use it.
Old 10-08-2013, 08:30 AM   #10
DIY staff
Rewards Points: 7,174
I use a drywall gun---and get close to 100 sheets out of a bit---or 10?
I buy a 25 pack twice a year----and change the bits without thinking----it's the spin out that kills them--and a drywall gun just doesn't do that often---
(DeWalt)
Old 10-08-2013, 12:42 PM   #11
Rewards Points: 4,784
I've never heard that, but I'll keep it in mind. Right off the top of my head though, it sounds like it might be the wrong size bit for the screw. Most people just pick Phillips without thinking size, while there are actually 8 different sizes - maybe 3 of those are common. Not only that, there is a Pozidriv and Frearson head (and some others as well) which look like Phillips but are not. Each of those takes a unique bit.
Most people don't know that Phillips heads are designed to cam out to avoid damage to the material or the driver. Nowadays drivers have good clutches on them (assuming they get set correctly) so the cam out irritates most people. It's mostly better to have the driver take care of overdriving with a clutch, and of course when driving by hand you can feel yourself when the bit is slipping or how much pressure is being applied.
The cam out is the reason that drywall bits work so well - when the flange makes contact with the wall surface, the bit cams out at exactly the right position, and all is well. So you probably ought to be using a drywall bit after all.
If you don't like that, then of course you can use 1 1/4" square drive or star drive screws if you like.
jeffnc is offline   Reply With Quote
Old 10-08-2013, 01:44 PM   #12
AHH, SPANS!!!
Rewards Points: 1,166
over the years I've used the shiny acr phillips 11 platinum bits with the little ridges on the tip.the ridges grab the screw and the bits last the longest compared to other bits IME but as Joe mention the new impact ready bit/tips are tougher.
hand drive is offline   Reply With Quote
Old 10-08-2013, 05:48 PM   #13
Someday maybe someone will be smart enough to put star, torx, or square drive on drywall screws. Almost anything would be better than Phillips except straight slot.
Nailbags (10-09-2013)
Old 10-09-2013, 12:01 PM   #14
Rewards Points: 626
Amen to that!
Old 10-09-2013, 12:07 PM   #15
JOATMON
ddawg16's Avatar
Rewards Points: 852
But imagine what that would do to the sales of phillip's bits? Just think of all the Chinese that would be put out of work.
What type of nails/screws should be used with furring strips? firsttimeremode Building & Construction 18 10-02-2012 09:30 AM
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Drywall Screw Selection DaveTile Drywall & Plaster 1 03-31-2011 12:17 PM
drywall screw pop ryanh Drywall & Plaster 4 03-19-2010 09:40 PM
Drywall screw inspection requirements? epeterson777 Building & Construction 11 03-30-2009 01:29 PM
