Drywall Screw Bit ? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 11:26 AM   #1
Rewards Points: 216
drywall screw bit ?
are these any good ? i would rather not buy a whole drill.
http://www.amazon.com/Vermont-Americ...ds=drywall+gun
Fix'n it is offline   Reply With Quote
Old 07-22-2012, 11:56 AM   #2
the Musigician
DangerMouse's Avatar
I'm confused. That is used IN a drill. ....and it's totally un-necessary.
I drywalled my whole house with a phillips bit in my variable speed drill.
DM
Old 07-22-2012, 12:02 PM   #3
bbo
I have one of those somewhere. I ended up buying a Hitachi drywall screw gun ( reconditioned) for less than 40$ shipped. looks like new, works like new. 40foot cord. no learning curve, dont have to pay attention to depth once set up. if doing a large area, I'd get a drywall gun. then again, I've never been shy about acquiring a new tool
bbo is offline   Reply With Quote
Old 07-22-2012, 05:56 PM   #4
Rewards Points: 199
I bought one of those but ended up not using it.
For my entire house, I used a DeWalt 12V impact driver.
I've found that it gives me gives me much finer control than a drill driver
for putting the screw head just barely below the surface.
That said, I've never used a dedicated drywall gun; I suppose that it would be much faster,
especially since it has the screws right with the gun on a strip.
However, for me, I don't think that I could have done a 'better' job if had I used a
drywall gun.
Arky
Arky217 is offline   Reply With Quote
The Following User Says Thank You to Arky217 For This Useful Post:
DangerMouse (07-22-2012)
Old 07-22-2012, 07:51 PM   #5
Rewards Points: 216
DM
yes, that is used in a drill. and yes, it is un-necesseary. but i have a bit of a habit of putting the screws in to far . and that tool would stop that, i think. making the job easier and faster.
Old 07-22-2012, 07:52 PM   #6
Rewards Points: 216
if i could get one for $40 otd, i think i'd buy it.
Old 07-22-2012, 07:53 PM   #7
Rewards Points: 216
i would waist so much time using my impact driver = screws to deep. my drill has much finer control, but its not perfect.
Old 07-22-2012, 07:57 PM   #8
bbo
http://bigskytool.com/Hitachi_W6V4G_...)___i2361.aspx
at the time, it was on sale for 34 with 6.80 shipping when I got it.
Old 07-23-2012, 08:56 PM   #9
Rewards Points: 212
http://www.homedepot.ca/product/dryw...-3-pack/933482
This is what we've used in finishing a basement. Works great.
With Phillips screw bit, tendency to sink too deeply and rip the drywall.
orange is offline   Reply With Quote
The Following User Says Thank You to orange For This Useful Post:
Fix'n it (07-23-2012)
Old 07-23-2012, 09:04 PM   #10
the Musigician
Variable speed and finger control. Never happened once to me!
DM
Old 07-23-2012, 09:08 PM   #11
jschaben
Rewards Points: 502
I have had one for awhile but just recently had a need to use it... Wasn't impressed. Usually kicked the screw loose a bit proud of the drywall and I had to go back and set the screws. Ended up finishing the job with the impact. The ones I have are the same as the ones in the posted home depot link. I think the problem was that I was working an old house and the studs weren't a consistant density. If I hit a hard spot when the cup was just starting to push the bit out, it would cam on me. Some places it worked great, others, not at all. If you have a lot to do, I would say the Hitachi would be $50 well spent.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 07-24-2012, 02:42 AM   #12
Davejss's Avatar
Rewards Points: 740
I use them from time to time. They work fine when I don't have my drywall gun with me and I'm doing a small job. The depth adjust works well. Its no replacement for an actual drywall gun but it's a heck of a lot better than trying to set a screw to the proper depth without one.
Davejss is offline   Reply With Quote
Old 07-24-2012, 07:09 AM   #13
Rewards Points: 2,210
A drywall gun does more than just set the screw to the proper depth - which is really important as to not tear the paper and give proper hold.
It also pushes the drywall against the stud as you screw making for way less pop outs later.
mae-ling is online now   Reply With Quote
Drywall Damage After Wallpaper Removal katega Drywall & Plaster 1 01-28-2012 11:11 PM
Drywall Damage After Wallpaper Removal katega Painting 10 01-26-2012 11:21 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
