Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 07-10-2011, 01:03 PM   #1
Thumbs down
Drywall Scratches
Hi everyone! Our family just moved into a brand new basement suite. It is almost completely underground (other than two feet with windows). When we moved in a piece of cardboard slid against the wall and caused a scratch. There was no pressure what-so-ever and the cardboard was very light. It caused us some concern, so I pressed the wall with my nail and it scratched so easily. Moral of the story, even the slightest/lightest hit to the wall cause a scratch. I am wondering why this would be? I don't want to lose our damage deposit because of this so I was wondering if you would know why the drywall would scratch so easily.
Thanks in advance for your help!!!
jodymcdonald is offline   Reply With Quote
Old 07-10-2011, 02:18 PM   #2
m1951mm's Avatar
Drywall Scratches
If it were me, I would let the landlord know of the issue now. It will do two things--Let the landlord know that you are concerned about the space that you moved into, and that you are concerned about the apperance and also let him know that if he had someone do the work on the walls that maybe they were not done the right way. Any time you rent and notice that something is out of place shows your landlord that you care about the property. Most landlords know that there maybe a bit of wall damage when moving furniture and other items in and they account for that. If you feel that the damage is due to more than just moving things in, I would let the landlord know quickly.
m1951mm is offline   Reply With Quote
Old 07-10-2011, 04:35 PM   #3
I make love to my walls
Drywall Scratches
Was the unit freshly painted recently prior to your moving in? If so are you sure it was the drywall that scratched or could it be the latex scratching off?
Arey85 is offline   Reply With Quote
Old 07-10-2011, 11:31 PM   #4
Moderator
Drywall Scratches
In a freshly drywalled basement, the drywall mud used for taping/texturing could still be wet with the concrete blocking drying to that side and paint slowing the inside drying. Hope they used fans or air dried long enough before you moved in.......Do you have an outside egress door or window other than interior stairs for a fire escape? http://docs.google.com/viewer?a=v&q=...33otStRi7Aff7g
Gary
Clothes taking longer to dry?
Old 07-16-2011, 05:31 PM   #5
Drywall contractor
Drywall Scratches
Possible that lightweight compound was used on the finishing. It scratches easily...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
basement, drywall, scratches
Rookie questions - drywall paper rips Eusibius2 Drywall & Plaster 13 08-14-2010 09:46 PM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 04:13 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 06:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
