Drywall Repair And Matching Texture Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-12-2010, 02:04 AM   #1
Rewards Points: 115
Drywall repair and matching texture question
My repairs are pretty good, but they really stick out because they're smooth compared to the roller nap texture on the rest of the wall. So, what would be a better way to match the texture from the paint roller nap on a drywall repair?
1. Thin some drywall compound and roll it on with a roller, which I assume would leave an nice textured nap.
2. Smooth and feather the repair as good as possible and roll several coats of paint and try to build up the nap to the existing wall.
Or is there a better way???
RickDel is offline   Reply With Quote
Old 08-14-2010, 12:53 PM   #2
Rewards Points: 558
I am assuming you are repairing a textured ceiling and the texture does not match any more with your new patch. Am I correct?
If so, the only way to correct this is to remove all the existing texture prime, patch with drywall compound, sand, prime again and then reapply a new texture finish to the entire ceiling which will now blend in your patch.
epson is offline   Reply With Quote
Old 08-14-2010, 04:46 PM   #3
Rewards Points: 115
thanks for the reply.... Actually, I was just trying to build the nap back up on a regular painted wall. I found a solution by using a 1/2 nap roller and apply multiple coats. Thanks Again.
Old 08-15-2010, 10:35 PM   #4
Rewards Points: 558
Glad it worked out for you...
Old 08-22-2010, 11:52 AM   #5
Drywall contractor
Rewards Points: 1,070
Or just start with a 3/4" or 1" nap roller.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Small Drywall Repair and Texture DoubleHumbucker Drywall & Plaster 5 10-17-2009 05:18 PM
Drywall texture matching budking Painting 3 10-29-2007 03:38 PM
