Drywall Repair? Hole In Wall Next To Doorframe - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-20-2010, 05:13 PM   #1
Drywall repair? hole in wall next to doorframe
Hey guys, and hope I'm not in the wrong section posting this,
I'm not too knowledgeable in the DIY repair world of things but I've happened across a fist-sized hole in my drywall 4 days before a surveyor is expected to come round to inspect the house for the people who recently gave us an offer! I know.. rather bad timing.
I did a quick google and found this:
http://www.ehow.com/video_4150_patch-hole-drywall.html
and this:
http://www.ehow.com/how_4916151_fix-...oles-wall.html
It seems simple enough to accomplish in 4 days I would hope however the only issue from simply following their instructions is that I have a door frame right next to my hole [see attached image].
Although I don't have a stud finder I did have some little magnets lying around and you should be able to see the 4 magnets surrounding the hole.
So I'm expecting it's not going to be quite as simple as that.. if it is great but if it isn't I was hoping someone could offer some insight into how to apply dry-wall to this area? Will the doorframe need to be removed?
Much thanks I will try to respond to any questions asap!
Charcoal is offline   Reply With Quote
Old 06-20-2010, 07:51 PM   #2
Handyman
Rewards Points: 512
you dont need to google... search the answer in this website. TONS of information here...
just search for small drywall repair or patchng holes in drywall...you will be overwhelmed with answers
canadaclub is offline   Reply With Quote
Old 06-21-2010, 06:12 AM   #3
WaldenL's Avatar
Rewards Points: 268
Hard to tell exactly how large that hole is, bug judgeing from the plate cover on the other wall, it's not too big. You don't need/want to go out to the studs. A simple drywall patch will cover that. You could clean up the edges and put a piece in or just use a mesh hole cover. Either way you'll be fine in 4 days, maybe even with paint. Will take 3 days to do the taping if you don't use hot mud.
WaldenL is offline   Reply With Quote
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
drywall on crooked wall drywall_trouble Drywall & Plaster 2 02-23-2009 08:39 PM
water damage remove mold & repair or replace drywall homerepair1 Drywall & Plaster 2 02-22-2009 10:00 AM
Hole in Cinder Block Wall for Small Air Conditioner stevehgraham Building & Construction 1 02-20-2009 06:31 AM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
