Drywall Repair Help - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-16-2015, 12:23 PM   #1
Rewards Points: 2
drywall repair help
I'm trying to redo my back splash in my kitchen, so I tore down the old ugly plastic one. When I did, the glue ripped a lot of the paint off the drywall and now it's peeling real bad. How do I fix this? Basically the white has peeled off in many places and now there is what I can only explain as a brown paper bag type of material showing through. I plan on painting my back splash instead of putting tile over it. Thank you!
amiles0026 is offline   Reply With Quote
Old 02-16-2015, 12:49 PM   #2
ZZZZZ's Avatar
Rewards Points: 1,714
I'm no drywall pro, but others have recommended a product like this. Available at that Big Orange Box store and elsewhere.
ZZZZZ is offline   Reply With Quote
Old 02-16-2015, 02:54 PM   #3
Rewards Points: 3,795
I've repaired much worse with nothing but drywall mud and time.
Remove all loose edges and start skimming in thin coats.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 02-16-2015, 03:03 PM   #4
Rewards Points: 13,472
I'd just replace it with new drywall.
Less materials and end up with a smoother finish.
Not suppose to " start skimming in thin coats"
You would cut out the loose areas and seal it with the primmer ZZZZZ suggested before trying to fill it in to seal it.
Drywall repair REXAMUS Drywall & Plaster 7 12-21-2011 03:24 AM
Suggestions to repair drywall around recessed light OhmZoned Drywall & Plaster 10 11-19-2011 06:07 PM
Using tape on a ceiling drywall repair janralix Drywall & Plaster 8 09-22-2011 10:07 AM
Drywall Repair - Paint peeled off down to drywall TJoy Drywall & Plaster 5 06-24-2011 02:48 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
