Drywall Repair Help - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 12:49 PM   #1
Drywall Repair Help
I have recently had my home re-piped with PEX due to an unfortunate leak I had, I have been repairing all the holes in my drywall myself. Half the holes (which are roughly 30 holes, ranging about 12"x12") are resulting in ripples in the paper tape I am using. I started the application with a layer of mud, then I would apply the paper tape (dry) over the mud. I would smooth it out and apply another thin layer of mud over the tape and let it sit for 24 hours. When I would come back the next day, some of the holes were fine and some of the holes had ripples in the tape. I re-taped some of the sides but sprayed the tape with a water bottle before applying it a second time with new tape. Doing it that way I got a little better results but still had a few ripples in some of the tape.
What am I doing wrong? Am I not getting the tape wet enough? I'm using pre-mixed compound straight out of the bucket... does my compound need to be diluted or thinned out a little bit? Any suggestions from a pro would help.
Thanks.
SooSooStudio is offline   Reply With Quote
Old 04-02-2012, 12:58 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
For the first coat,do as you were but,one you put the tape on the mud go over the tape with your knife at a 45 angle then again closer to 90 all the while applying more and more pressure.
You want to push as much mud as you can out from behind the tape.
sublime2 is offline   Reply With Quote
Old 04-02-2012, 02:24 PM   #3
Rewards Points: 1,092
http://www.drywallschool.com/
The Following User Says Thank You to jklingel For This Useful Post:
M3 Pete (04-03-2012)
Old 04-06-2012, 12:47 PM   #4
Drywall contractor
Rewards Points: 1,070
Do not apply another coat of mud over wet tape. Tape must be thoroughly dry before a second coat is applied, especially if there are any gaps in the drywall. If you're in a hurry and trying to save a step, Tape with a setting type compound (45 or 90 min.) and come back in a couple of hours with your second coat....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
Ironlight (04-06-2012)
Drywall repair REXAMUS Drywall & Plaster 7 12-21-2011 03:24 AM
Suggestions to repair drywall around recessed light OhmZoned Drywall & Plaster 10 11-19-2011 06:07 PM
Using tape on a ceiling drywall repair janralix Drywall & Plaster 8 09-22-2011 10:07 AM
Drywall Repair - Paint peeled off down to drywall TJoy Drywall & Plaster 5 06-24-2011 02:48 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
