Drywall Repair Around New (trimless) Windows - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 11:40 PM   #16
MarginallyQualified
Rewards Points: 2,464
Originally Posted by coupe View Post
it's not Vinyl J channel.
it's Vinyl L bead with a rip away strip...
I've only done this once.
I used the vinyl J Channel on the GWB that butted up to the window.
It came out perfect(with a bead of caulk).
Old 03-27-2013, 07:31 AM   #17
Rewards Points: 5,974
it's not Vinyl J channel. it's Vinyl L bead with a rip away strip, it staples in tight to window, after finishing out to corner, you pull the rip bead out for nice smooth line against window frame. a tiny bead of caulk cleans it up nice against window or could use a paper tape on L bead
Exactly what I was going to recommend tear away bead. The tear away part keeps the mud from where you don't want it. Then when mud is dry tear the strip off and you have a nice straight line. Also a great product for anytime drywall meets another surface such as brick or stone. Lets you mud the edge of the drywall without getting mud on the brick, whice is a beatch to remove.
Drywall repair or cover it up? flyingmachine Drywall & Plaster 4 01-21-2012 06:32 PM
Drywall repair REXAMUS Drywall & Plaster 7 12-21-2011 03:24 AM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 06:25 AM
drywall repair next to an outlet - advice needed... myke232 Drywall & Plaster 2 08-19-2009 12:25 PM
Minor Drywall Repair leted_82 Building & Construction 3 10-11-2007 09:57 AM
