-   -   Drywall repair around new (trimless) windows (http://www.diychatroom.com/f101/drywall-repair-around-new-trimless-windows-175493/)
stencil 03-25-2013 03:17 PM
2 Attachment(s)
Hello, so I replaced all the old aluminum-frame windows in my house recently. to do so, I had to cut about 1/2-inch (in some cases more) of drywall away from the frames (see pics). Any thoughts on how to repair these cuts? Should I just fill them with mud and caulk the seam where the mud meets the window? My father-in-law recommended filling the larger gaps with pieces of drywall (not sure how I'd secure them...). Thanks for any help!
joecaption 03-25-2013 03:31 PM
Whole lot easyer and come out looking better to just remove it and replace those pieces.
Second best would be to get rid of the loose paper and use what's called hot mud.
It comes in a bag and has to be mixed with water.
You can get 30, 60, and 90 min. hardning times.
If you use it I would use a 4" knife to fill in the gap and one wide enough to come all the way out to the outside corner to smooth it out.
http://www.usg.com/sheetrock-easy-sa...-compound.html
stencil 03-25-2013 04:02 PM
Thanks joecaption! I'll look into the hot mud, but now that you mention it, the drywall around a few of these windows is cracked and damaged...I might just replace it...that said, I'm pretty sure the corners have metal corner beads. Do you know of a good/easy way to remove those? I can just see this whole thing spreading out from the window as I go...
joecaption 03-25-2013 04:06 PM
Your going to think I'm joking but just take a hammer and and tap it down along the outside corner. The compound will just crack and fall off exposing the metal bead so you can pry out the old nails.
No chance you want to consider just going over the old dry wall with wood instead and add some casing?
stencil 03-25-2013 04:30 PM
That makes sense, thanks! As for the wood casing, it was a thought, but the wife shot it down...
joecaption 03-25-2013 04:43 PM
When I get stuck doing drywall returns like that I try to get the customer let be use rounded corners instead of square.
Makes a huge differace in the finished look. It softens the whole opening is the best way I can describe it.
http://www.bing.com/images/search?q=...electedIndex=1
Adding a stool like this one in the picture gives her a place to set Christmas candle, some plants or knick nacks.
Beepster 03-25-2013 05:01 PM
Not to hijack a thread, but to add more information to it:
Any rule of thumb when to use wood in this area and when to use drywall, or the tradeoffs?
I am just about to the point where I have to do this in our basement, but while out on a Parade of Homes tour over the weekend, i noticed more than a few that had drywall inside and just wood at the bottom with trim as Joe had in the pic in his last post.
B
joecaption 03-25-2013 05:07 PM
I've seen a ton of water stained drywall returns on the bottom from condinsation.
coupe 03-25-2013 05:24 PM
this has worked great for me several times
http://www.clarkdietrich.com/product...ad-l-trim-vlzl
joecaption 03-25-2013 05:56 PM
What's that product got to do with finishing out the outside corners?
Beepster 03-25-2013 07:22 PM
Yes, wood on the bottom is a given, but no issues with drywall on the sides and top if the installer wants to take the time to fuss around with the details?
B
coupe 03-26-2013 03:03 PM
the OP made no mention of outside corners, nor do pictures indicate problems there
you're welcome
żżż
TarheelTerp 03-26-2013 03:32 PM
Vinyl J channel where the gwb meets the window
joecaption 03-26-2013 03:36 PM
"Thanks joecaption! I'll look into the hot mud, but now that you mention it, the drywall around a few of these windows is cracked and damaged...I might just replace it...that said, I'm pretty sure the corners have metal corner beads. Do you know of a good/easy way to remove those? I can just see this whole thing spreading out from the window as I go... "
Sure sounded like they were asking about the outside corners to me.
coupe 03-26-2013 06:28 PM
it's not Vinyl J channel. it's Vinyl L bead with a rip away strip, it staples in tight to window, after finishing out to corner, you pull the rip bead out for nice smooth line against window frame. a tiny bead of caulk cleans it up nice against window or could use a paper tape on L bead
