Drywall Repair Around A Bullnose... - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-30-2009, 03:49 PM   #1
Rewards Points: 110
Drywall Repair around a bullnose...
Hi there. I think I know the answer, but I need reassurance.
Some repairing/remodelling I am doing requires that I butt up a new piece of drywall to an existing edge. This existing edge just so happens to be a bull nose. In fact, it is a header over an entrance way we are closing off. So I have a bull nose running floor to a height of 80 inch, and then across 72 inch to the wall.
This is in the basement, and because of low ceiling height, there is only about 6 inch from the horizontal bull nose to the ceiling. Likewise, on the vertical bull nose, there is a door right next to it, so the casing for that door is only about 5 inch away from the vertical bull nose.
Any the question is;
Can I butt up my new drywall to these existing bull noses, and feather it out with mud, or is it going to look like mud
Emma is offline   Reply With Quote
Old 03-31-2009, 06:13 AM   #2
Rewards Points: 5,336
You would need to tape the seam. The final outcome would depend on your taping/mudding skills.
Ron
Old 04-06-2009, 04:44 PM   #3
if it was me i would beat the old bead off and pre-fill with sheetrock 90,you dont know how well that bead is applied,is it stapled,glued,screwed?who knows,do it right,it will turn out better if you go down to the base!
HOMEY is offline   Reply With Quote
Lots of damaged drywall - repair or replace? jdelisle Remodeling 25 04-04-2011 06:37 AM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
Minor Drywall Repair leted_82 Building & Construction 3 10-11-2007 09:57 AM
Drywall and Plaster Repair argana Building & Construction 8 09-15-2007 02:13 PM
