Drywall Repair After Wall Removal - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-19-2012, 09:11 PM   #1
Drywall repair after wall removal
I bought a house and removed two non-bearing walls. I'm not sure how to repair the walls and ceiling because there are no joists in the ceiling where the wall attached to the ceiling. It is a trussed roof so the ceiling pitches from 8 to 11 feet. What do I attach the drywall to? Is this a job for a Professional? Am I out of my league here? What would something like this cost for a Professional to repair? Please help!
kman1455 is offline   Reply With Quote
Old 02-20-2012, 08:47 PM   #2
retired union carpenter
Send a message via Yahoo to coupe
you're going to have to place some blocking 2' on center to attach your new walls to. may have to cut back more drywall to do so?
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-21-2012, 07:35 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Ditto.
titanoman is offline   Reply With Quote
Old 02-21-2012, 08:01 PM   #4
Drywall contractor
Rewards Points: 1,070
Actually 16" centers would be better....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywall over 4" block wall base JustADoc Drywall & Plaster 7 09-12-2011 11:47 PM
Repair of drywall. Noticed bad insulation yardlady General DIY Discussions 3 09-04-2011 08:50 AM
How to drywall wall with HVAC trunk and pipe penetrations daphilli Drywall & Plaster 3 09-27-2010 03:15 AM
Repair drywall behind mirrored wall that were removed Donna34655 Drywall & Plaster 2 05-10-2009 05:42 AM
drywall on crooked wall drywall_trouble Drywall & Plaster 2 02-23-2009 09:39 PM
