Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 03-09-2010, 08:51 PM   #1
Drywall Repair
I had some damage to my drywall thanks to a fish tank I had. You can see the damage here:
Unfortunately, the damage is not just the paint chipping off. It appears to be a little more than that. Is there a simple fix for this?
Willie5566 is offline   Reply With Quote
Old 03-09-2010, 09:19 PM   #2
Super Moderator
Drywall Repair
It look like moisture softened up some of the drywall mud---Not a big problem--scrape and sand the area and patch with some drywall mud--the stuff with the dark blue lid should do fine.
Use a 6" blade and sand--Presto--all fixed---Mike---
Old 03-10-2010, 10:18 AM   #3
Drywall Repair
Is dry wall mud hard to use? I think I have seen some posts on here about it being an "art." Any tips on making sure it looks good?
Old 03-10-2010, 10:22 AM   #4
Chaos Engineer
Big N8's Avatar
Drywall Repair
THIN to WIN. spread the coat very thin and take your time. also sand the area before you mud.
Big N8 is offline   Reply With Quote
Old 03-11-2010, 08:42 AM   #5
Drywall contractor
Drywall Repair
Yep, a couple of thin coats is preferable to trying to "pile" it on and cover with one coat. If there is a tape joint in there and the tape is loose, the tape will have to be removed and new tape put in....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
drywall repair next to an outlet - advice needed... myke232 Drywall & Plaster 2 08-19-2009 01:25 PM
New Home - Wavy Drywall Seams Repair ?'s bmmitche Drywall & Plaster 2 07-19-2009 05:28 AM
Best way to repair poor drywall installation? RyanD Drywall & Plaster 5 05-19-2009 09:13 AM
Minor Drywall Repair leted_82 Building & Construction 3 10-11-2007 10:57 AM
Drywall and Plaster Repair argana Building & Construction 8 09-15-2007 03:13 PM
