-   -   Drywall Repair (http://www.diychatroom.com/f101/drywall-repair-66417/)
Willie5566 03-09-2010 07:51 PM
Drywall Repair
I had some damage to my drywall thanks to a fish tank I had. You can see the damage here:
http://i30.photobucket.com/albums/c3...e/P1000923.jpg
Unfortunately, the damage is not just the paint chipping off. It appears to be a little more than that. Is there a simple fix for this?
oh'mike 03-09-2010 08:19 PM
It look like moisture softened up some of the drywall mud---Not a big problem--scrape and sand the area and patch with some drywall mud--the stuff with the dark blue lid should do fine.
Use a 6" blade and sand--Presto--all fixed---Mike---
Willie5566 03-10-2010 09:18 AM
Is dry wall mud hard to use? I think I have seen some posts on here about it being an "art." Any tips on making sure it looks good?
Big N8 03-10-2010 09:22 AM
THIN to WIN. spread the coat very thin and take your time. also sand the area before you mud.
bjbatlanta 03-11-2010 07:42 AM
Yep, a couple of thin coats is preferable to trying to "pile" it on and cover with one coat. If there is a tape joint in there and the tape is loose, the tape will have to be removed and new tape put in....
