Drywall Repair - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-30-2012, 10:38 AM   #1
drywall repair
hello , i have a simple question about drywall repair .
i have seen work where people have used joint compound
on repairs and you see the repair because it goes from
a sort of textured look to a smooth spot ( were the repair is )
back to a textured look . it doesn't blend into the wall well .
is there a way to make the repair look like the rest of the wall
to an unnoticeable repair ?
raspy is offline   Reply With Quote
Old 07-30-2012, 10:46 AM   #2
Rewards Points: 2,212
Drywall compound works fine.
Use a roller to prime and paint, sanding between coats.
I like it best to paint from one corner to another, no just the patch. Paint color may be slightly off and noticeable.
mae-ling is offline   Reply With Quote
Old 07-30-2012, 11:57 AM   #3
ok you prime then paint then you sand between coats of paint ? what does sanding after a coat of paint
do ? ive never heard of that .
thx for the reply
Old 07-30-2012, 07:21 PM   #4
Rewards Points: 512
you sand between coats for a smoother finish. rollers always pick up dust or small chunkies in the paint,etc.
and yes i'd prime the area that was patched using a thicker roller sleeves like a 3/4 to get a closer match to the "texture" on the wall.
princelake is offline   Reply With Quote
Old 07-30-2012, 07:57 PM   #5
great thx , i was wondering why it didn't match the wall well , ive even seen paint commercials
were they show people who painted there walls and you can see the repairs . kind of odd
most people probably don't even notice it till they try to repair there own walls .
Old 07-30-2012, 08:04 PM   #6
bbo
also feather the texture into the existing wall with your joint compound. unless you are great at texturing it will easily show if you don't "feather" it in.
bbo is offline   Reply With Quote
Old 07-30-2012, 08:58 PM   #7
Rewards Points: 512
when patching you fill all the pores making it nice and smooth whereas the rest of the wall has pores and has a really light texture.
Drywall repair REXAMUS Drywall & Plaster 7 12-21-2011 03:24 AM
Suggestions to repair drywall around recessed light OhmZoned Drywall & Plaster 10 11-19-2011 06:07 PM
Using tape on a ceiling drywall repair janralix Drywall & Plaster 8 09-22-2011 10:07 AM
Drywall Repair - Paint peeled off down to drywall TJoy Drywall & Plaster 5 06-24-2011 02:48 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
