Drywall Repair - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 09:55 AM   #1
Drywall repair
How do I cut out a section of dry wall for replacement?
mjordan is offline   Reply With Quote
Old 11-15-2011, 10:22 AM   #2
General Contractor
How big of an area?
Reciprocating saw, being careful not to plunge the blade deep....held more parallel to the wall rather than straight on, particularly important while cutting in the bay(horizontal area between studs so you don't cut a wire or plumbing) Vertical, you can find the stud centers and cut down the middle to avoid adding blocking.
Jab saw, if you plan on adding blocking because they're more for cutting a hole in the field rather than on the edge of a stud.
Or a razor knife, just takes longer and multiple passes on the same cut line to cut deep enough to get through the drywall.
My favorite for patching is an oscillating tool like the fein, much cheaper versions can be purchased.
dsconstructs is offline   Reply With Quote
Old 11-15-2011, 10:52 AM   #3
Old School
Willie T's Avatar
Originally Posted by dsconstructs View Post
How big of an area?
I second that. I have a Sears model.
Willie T
Old 11-15-2011, 12:15 PM   #4
General Contractor
Harbor Freights has a coupon out right now for $19.99 for the corded version, regularly $59.99
If I didn't already own 2 feins.........
Old 11-19-2011, 04:56 PM   #5
Too Short? Cut it Again!
The Fein I bought years ago was one of my most used tools and even though expensive it more than paid for itself. Others on this site have had reasonable things to say about the cheaper brands (search the tools forum) like Rockwell, Craftsman, Harbor Frieght and so forth. I should think for $20 a consumer model would be worth a try.
Before getting too carried away around areas where their might be electrical or plumbing runs, you might want to cut or drill a hole just large enough to get a mirror in to see where you are headed?
Suggestions to repair drywall around recessed light OhmZoned Drywall & Plaster 10 11-19-2011 06:07 PM
Using tape on a ceiling drywall repair janralix Drywall & Plaster 8 09-22-2011 10:07 AM
Drywall Repair - Paint peeled off down to drywall TJoy Drywall & Plaster 5 06-24-2011 02:48 PM
Fixing drywall repair ddot Drywall & Plaster 7 05-18-2010 02:56 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
