Drywall Rates? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 03:23 PM   #1
Drywall rates?
I'm wondering what everyone is getting for drywall rates? I've heard that $1-$1.25 per sq ft is the nominal going rate for drywall installation, tape and float and have it ready for painting. I recently requested a bid and they quoted me somewhere around $3.50/sq ft.... I'm in a rural area, but that seems like highway robbery. Also, if there's anyone in SE Texas that wants work, I'd love to get a bid from you!
Robert-in-Texas is offline   Reply With Quote
Old 10-28-2008, 05:28 PM   #2
Rewards Points: 5,336
The quote isn't simply a matter of sq. ft. The onsite conditions will play a part, especially if it's a complicated job.
Ron
Old 10-29-2008, 11:21 AM   #3
Drywall rates? On-site conditions
Onsite conditions: I've removed all of the former ceiling, so that bare rafters are showing. I.e., there's no old-drywall to remove. I've already installed the electric boxes where I want them. It's ready for someone to come in and start putting drywall in place. The house is on pilings, so, yeah, they'd have to carry the sheets up some stairs to the main floor. But, that's the only thing unusual about the job.
On a side query... while I'm waiting to find someone to do this -- or, to decided whether I should tackle it -- I'd like to cover the rafters with something so that my front room isn't exposed to the attic area. I was thinking about stapling Tyvek to the rafters... would that be okay? Would it have to be removed when the drywalling starts?
Old 10-29-2008, 11:44 AM   #4
Details I was looking for would include:
Size of the area(how many sheets?)
Height of the ceiling?
Soffits?
Window,door returns?
Type of sheetrock?
-walls
-ceiling
Call in other contractors for an estimate. In my experience, commercial guys charge more then residential contractors.
Ron
Old 10-29-2008, 11:50 AM   #5
Area is 44' x 26' .. I estimate 36 sheets of 4' x 8'
Height of the ceiling? 96 inches
Soffits? nope
Window,door returns? nope
Type of sheetrock? mold-resistant
-walls Nope
-ceiling Yes
This is just the ceiling of the large living room area, at 96 inches.
Any opinion about using Tyvek to seal off the rafters?
Old 10-29-2008, 12:30 PM   #6
So the entire job is ceiling work. Pro's will use 10-12' sheets to minimize the joints.
I see no problem with Tyvek in that application.
Ron
That's $4000.+ for the job. That seems very high to me.
Old 10-30-2008, 03:17 PM   #7
Thanks for your comments!
Any comments about DensArmor mold-resistant drywall? If I were trying to avoid possible future mold events, would this be worth installing over paper-backed products?
Old 10-30-2008, 04:15 PM   #8
Is this job the result of a mold issue? Was this due to a water incident? Mold growth would be unusual in an above the ground environment without some sort of water episode.
I've never used the product myself. I've never had an issue with just moisture resistant sheetrock(greenboard).
Ron
Old 10-30-2008, 04:23 PM   #9
Yes, part of the roof came off and there was a lot of water (from rain) that came in through that route, ruining the suspended ceiling that was there. I ripped out the grid and plan to install greenboard or this DenArmor, just in case there is water incursion in the future.
Old 10-30-2008, 04:59 PM   #10
Greenboard is pretty good with water. I'm renovating a vacation house in upstate NY for a customer whose pipes froze last Winter. Water sprayed on the back of the greenboard for a week or so. It's still intact. The paper is still attached and the tiles are still on the front. I was very surprised at it's resilience.
Once I finish the first floor, the second floor will get gutted and cement board installed in the shower, but for now it's the only functioning bath in the house.
I don't know how well it would have done in your situation though.
Whatever material you chose, the weak link will be the compound, as it's water soluble.
Ron
Old 10-31-2008, 09:13 AM   #11
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
I just had my 30'x46' garage ceiling hung, taped, KD textured and painted. 4'x12'x5/8", $2100.
comp1911 is offline   Reply With Quote
Old 10-31-2008, 09:47 AM   #12
Thanks comp1911! I appreciate the photo and the price you paid. $1.52 sq ft is a whole lot cheaper than what I was quoted.
Old 10-31-2008, 11:11 AM   #13
Rewards Points: 562
do those two prices stated above include the price of the rock?? OR just labor ,,,finish materials only???
4just1don is offline   Reply With Quote
Old 10-31-2008, 11:20 AM   #14
In my case ($4000+ for 44' x 26') was for all labor and materials.
Old 10-31-2008, 02:55 PM   #15
Jay123's Avatar
iirc I had a project quoted with DensArmor mold-resistant drywall a couple of years back and it was more than double the standard rate due to:
1) cost of material compared to standard drywall
2) finish required a level 5 finish (ALL rock skimmed with mud/sanded, due to the texture of the sheetrock). This is opposed to just taping/mudding the seams/corners.
You may want to check with your drywall contractor and see how it would compare with standard sheetrock before you start thinking you're getting ripped off....just a thought. Doesn't hurt to ask for an explanation.
J
Jay123 is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Drywall - Horizontal or vertical slinku2020 Drywall & Plaster 27 04-08-2010 12:40 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
