~Drywall questions and concerns~
Drywall is one of those things you learn how to do the hard way....just do it...
On those corner beads...I don't think I would want to reuse them...more work to clean them up vs just buying new ones....as for the rust....I have seem them rust just from the moisture from the mud....but you mentioned a leak...so that could have added to the issue....
I have had good luck using a heavy knap roller when I put on the primer....keep using the same roller for paint and it will do enough texture to hide most defects.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
