Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-11-2009, 08:06 PM   #1
Drywall Question
Hello, Can Mold & Water resistance dry wall be installed on all the walls in a bathroom. Can they be taped and finished (painted) like normal drywall .I,m going to use Handi Backer on tub and shower walls under tile. Thank you
kerry42 is offline   Reply With Quote
Old 11-11-2009, 09:23 PM   #2
Carpenter
Drywall Question
Yes install on all the walls and ceiling in a bathroom, if its paper faced it should be green(most common) blue or purple, If its a fiberglass face you will need to skim coat the entire surface.
Sewell,NJ is offline   Reply With Quote
Old 11-12-2009, 07:38 AM   #3
Remodeling Contractor
Drywall Question
the green board should not be used for wet areas. But you are using the CBU which is correct. But these seams should be taped also and this wall coated with a waterproofing material like Redguard.
Old 11-12-2009, 07:47 AM   #4
gravity always wins
Drywall Question
If it's not in a shower, use Densarmor. Green or blue board is still paper faced. If it's in a shower and will get covered by tile then use cement board or Densguard. My experience has been that if you prime and paint it right, you don't need to skim coat fiberglass faced drywall.
Old 11-13-2009, 05:03 PM   #5
Drywall contractor
Drywall Question
The little bit of DensArmor I've used needed a glaze coat to get a smooth finish. Maybe it has changed. Don't waste your money on green board. Regular drywall will work just fine if proper ventilation and appropriate paint are used.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
drywall question Curious Homeown Drywall & Plaster 4 11-04-2009 05:09 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Drywall question Not Sure Building & Construction 6 08-27-2006 04:05 PM
Easy Drywall Question hohandy Building & Construction 10 12-16-2005 01:18 AM
