Drywall Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-02-2009, 06:09 AM   #1
Drywall Question
So i am supposed to have a delivery of drywall tomorrow and the forecast is for rain. They will dump it in my driveway, but it may take me a few hours to get all of it inside. Including the time on the truck and in my driveway should i worry about the rain and water soaking into it? mold eventually forming?
thanks
baum is offline   Reply With Quote
Old 10-02-2009, 06:35 AM   #2
As long as they stack it on some dunnage and cover it properly it should be alright. Make sure they know you won't be able to move it right away so they'll cover it(Call the dispatcher and leave a note).
jerryh3 is offline   Reply With Quote
Old 10-02-2009, 06:37 AM   #3
The only downfall is i am getting it from a "big box store" (menards) will they do that?
Old 10-02-2009, 06:44 AM   #4
Not sure. Just call and ask. If you're ordering from a box store offer to buy a tarp from the store if they are a little hesitant.
Old 10-03-2009, 09:14 AM   #5
Drywall contractor
Rewards Points: 1,070
They SHOULD have it covered when delivered if there is rain likely. I would call and confirm. If not, postpone delivery. Aside from the mold possibility, wet drywall tends to break apart when you try to pick it up. You will lose at least the top couple of sheets. As long as the paper "tabs" remain on the ends of the bundles, the rock will be ok sitting out as long as it's covered. If the tabs are pulled, the board tends to absorb moisture through the ends (where it isn't covered with paper). The core of the board is porous and absorbs moisture from the surrounding air like a sponge. When I used to hang new houses (no controlled humidity) we pulled the tabs on the rock as we used it during rainy/humid times....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-03-2009, 09:56 AM   #6
well thanks for the pointers. It was delivered, covered and they droped it in my garage . Their truck seperated from the trailer and the back of the truck had a fork built into it. im in a townhouse so they just un-hooked at the end of the row of homes and drove the truck with the goods to my garage. i got it in the basement already (steps only).
Ecorock (new green drywall product) Sir MixAlot Drywall & Plaster 0 06-20-2009 08:40 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Drywall question Not Sure Building & Construction 6 08-27-2006 03:05 PM
Easy Drywall Question hohandy Building & Construction 10 12-16-2005 12:18 AM
