Drywall Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By rjniles
  • 1 Post By jlhaslip
Old 04-20-2017, 10:11 PM   #1
Rewards Points: 64
Drywall question
I cut off 3 layers of drywall off this wall to gain an inch of space. How do I clean up this corner?
I'm thinking cut along the pink line to get access to the corner framer. Remove the corner. Then install 1/2" greenboard on the wall with an X on it. Then install a new corner and replace the skinny slither removed from wall Y.
jaketrades is online now   Reply With Quote
Old 04-21-2017, 01:36 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,818
Re: Drywall question
What is on the other side?
I'm not liking your idea too much...there must be a better way
ddawg16 is online now   Reply With Quote
Old 04-21-2017, 05:27 AM   #3
Rewards Points: 64
Drywall question
Wall X & Y have three layers of 5/8" material. Sheet rock, brown board, sheetrock, then a few inches (8" or so for wall Y, ~4" for wall X) of plumbing and empty space. Then the next condo with the same layering of boards.
I cut off the layers on wall X because I needed the space in that direction.
Any ideas on what I can do here?
Old 04-21-2017, 05:56 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
You are in a condo, are you sure you have not opened a fire rated wall?
Sent from my RCT6203W46 using Tapatalk
jlhaslip likes this.
Coastal South Carolina
Old 04-21-2017, 05:59 AM   #5
Rewards Points: 64
No that brown board soundboard. I'm replacing with fire-rated drywall and tile.
Old 04-21-2017, 06:15 AM   #6
Rewards Points: 3,892
I'm thinking they didn't install all of those layers because they had surplus material just hanging around. I bet they were a required part of the building plans. Being a condo others may have a say in your modifications. Not trying to be a pain, condo's already provide that service.
Bud
Bud9051 is offline   Reply With Quote
Old 04-21-2017, 08:05 AM   #7
Rewards Points: 64
Drywall question
there is nothing in local code that says I can't build as I specified.
Now that I have the part of the ceiling open, I can see my upstairs neighbor's contracter decided to use romex and pvc pipe in their remodel when code calls for shielded cable and cast iron.
I'm not saying that 2 wrongs make a right but at least I'm following code.
Old 04-21-2017, 08:22 AM   #8
jlhaslip's Avatar
Rewards Points: 2,132
Just be certain to replace the layers as per originally found.
The multiple layers are there for a reason.
Double 5/8 is a fireguard. Soundboard is for sound, of course.
Liability will bite you in the arse if you scrimp on the designed system.
Fire code trumps the building code.
Bud9051 likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old Yesterday, 05:20 AM   #9
Rewards Points: 64
I'm putting in double 5/8". That still leaves me 5/8" off the corner. Meaning wall X's right corner is 5/8" shallower than wall Y's left corner.
How can I fix that?
Old Yesterday, 05:26 AM   #10
jlhaslip's Avatar
Add another layer of 5/8.
Old Yesterday, 05:39 AM   #11
Rewards Points: 64
The reason I don't want to do that is I'd lose length in the bathroom.
Is there another way?
Old Yesterday, 08:33 AM   #12
Rewards Points: 64
I have an idea to fix this....
1) Cut along the pink line just to the left of the metal stud. This stud will be the nailer for the existing wall.
2) insert a wooden sister stud inside the metal studs open face. I can't use a metal stud as a sister because the existing metal stud faces the wrong way. See second pic.
Or As an alternative to sistering in step 2 I could insert a metal stud into the existing track at the top and bottom. However I don't think cutting the wall to the ceiling will expose the top of the track because it's a dropped ceiling.
3) insert a strip of Sheetrock to replace the removed piece and screw to the new sister in step 2 and the corner. Insert a corner piece and I'm now flush at the two walls.
The controversial drywall question JonCiccarone Drywall & Plaster 13 04-17-2016 07:16 AM
Question, hanging drywall in the garage WCR Drywall & Plaster 11 01-13-2013 07:09 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Drywall question Not Sure Building & Construction 6 08-27-2006 03:05 PM
