drywall question
These areas need to be: Filled in with a 12" knife or trowel of compound.
Allow the area to dry. This need to "bridge" the area that is less than the connected seam. Essentially, you would fill-in the "crevice" portion.
After it dries, scrape or sand the imperfections.
Recoat, with a thinner layer, that extends beyond the 1st coat.
Recoat, with an even thinner layer, that extends beyond the 2nd coat.
After it dries, scrape and sand the imperfections.
Repeat the last step until it is properly blended.
The key point is to blend the area, so that it is not visible to the naked human eye.
Example: If you were to take a 6' or longer level (or straight edge) and place it against any drywalled ceiling or walls, I guarantee, that it will never sit fully "flat".
However, to the naked human eye, you can't see that, and it appears flat thru proper spreading and blending of areas ... and a proper primer and paint application.
- Build Well -
