Drywall Quest. - Tub/shower Traps Below Joist Level - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-21-2013, 08:05 PM   #16
Tileguy
JazMan's Avatar
Rewards Points: 422
So, what's the problem? I don't see why it can't be trimmed. Got a pic?
Jaz
Old 02-21-2013, 08:15 PM   #17
ARB
Rewards Points: 99
Here ya go...
ARB is offline   Reply With Quote
Old 02-21-2013, 09:04 PM   #18
Tileguy
JazMan's Avatar
Rewards Points: 422
I see where you can cut off about 3/8" looks like. Just above the trap & the brass drain, I do believe.
Jaz
Drywall Quest. - Tub/shower traps below joist level-p-trap.jpg
Old 02-21-2013, 09:10 PM   #19
Rewards Points: 960
Big ass light fixture (BALF) underneath.
cleveman is offline   Reply With Quote
Old 02-21-2013, 09:13 PM   #20
ARB
Rewards Points: 99
Jaz
Thanks Jaz, I think I see what you mean... If I went this route, am I correct that I'd need to remove (and replace) everything up to the "main line" in the upper left of the photo?
Old 02-21-2013, 09:16 PM   #21
Tileguy
JazMan's Avatar
Rewards Points: 422
Yes, those are all glued together. I don't think using any solvent will release the glue. But I'm no plumber and haven't had the problem. While you're at it, see if you can get a slightly smaller trap.
Jaz
Old 02-21-2013, 09:19 PM   #22
ARB
Rewards Points: 99
Jaz
Thanks, I appreciate your help!
Repair/replace sill plate and joist ends heybales Building & Construction 5 02-16-2013 10:33 PM
Attach Drywall through plywood HooKooDooKu Drywall & Plaster 2 01-20-2010 10:05 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
question about joist hangers with drywall redss Drywall & Plaster 4 10-15-2009 02:01 PM
