Drywall Putty Question - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-21-2010, 11:43 AM   #1
Drywall Putty question
Hello!
I am redoing one of the walls downstairs in my family room. It was wallpapered and when I took down the wallpaper the wall was just in horrible shape. I have torn down the drywall and put up the new. I cut the tape where the wall met the ceiling when I tore down the old. I have textured ceilings. Obviously if I taped it to the ceiling, it would ruin the texture. I have about a 1/4 to 1/2 inch gap where the drywall meets. Would I be able to just put joint compound in there? I was told to use plaster of paris because it is a bit harder and might not crack as easily. What alternatives do I have to filling the gap and making it look pretty without ruining the ceiling.
Thanks,
Vince
VinceA is offline   Reply With Quote
Old 10-23-2010, 08:39 AM   #2
Drywall contractor
Rewards Points: 1,070
Crown mold. Anything you pack in the crack will eventually crack without angle tape....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 10-23-2010, 09:31 AM   #3
Crown molding won't work in this room. It will be very out of place.
Old 10-23-2010, 10:39 AM   #4
Drywall contractor
Pre-fill the gap with a setting type compound, flat tape and finish, then caulk at the top. It will last longer due to the caulk's ability to flex a bit. Best of luck......
The Following User Says Thank You to bjbatlanta For This Useful Post:
Axecutioner-B (10-28-2010)
Old 10-23-2010, 05:26 PM   #5
How would filling the majority of the gap with a caulk and then putting the compound over that work? The gap in most places is 1/8 of an inch or less, there really isn't much needed.
Old 10-23-2010, 05:50 PM   #6
Jack of all trades
Superintendent's Avatar
The wall, is it a perimeter wall or a interior wall?
The reason I am asking, an interior wall has more movement due to the truss deflection.
As the other member stated, if you do not tape that, it WILL crack sooner or later without doing a tape job.
You could scrape enough of the texture away, tape, then do a minimal texture repair.
You can pick up a cheap texture gun for say $30-50. Meaning one of the little syringe looking types. They do a pretty good job if you take your time and set up your mixture properly.
Superintendent is offline   Reply With Quote
Old 10-23-2010, 07:31 PM   #7
It is an exterior wall on the back of the house. The bottom of the wall is cinderblock, and the framing sits on top of that. I can't see it shifting much. I understand that it will crack no matter what, but if it's going to last a while and it is something I can repair before a new paint job, it isn't a huge deal to me. The ceiling is one of those little circle patterns, and any change will be fairly noticeable. I really want to do it the best way, but I can't see a way to tape it and the job looking normal.
Old 10-25-2010, 08:50 AM   #8
How would caulking it work? Either with an acrylic or silicone caulk. And then put a very light coat of compound over that.
Old 10-25-2010, 05:24 PM   #9
you basically have two choices
A: caulk the crack
B: sand down 12-18" or so on the ceiling and wall, re tape and re texture
GE makes a 1hr caulk that's very very flexible and extremely sticky. it's $7 a tube at HD but is better than any other caulk i have used. i just tried it on a couple hairline cracks i had and it did the job. 1/8" won't be a problem but you will want either a finger or popcicle stick to get a nice uniform look after you apply it
caulk works on drywall as long as it's sticky enough to really grab. if it isn't the caulk itself will come loose.
i would not use any joint compound, setting or otherwise on that gap without tape. it's going to crack. just paint over the caulk if you go that way, no compound.
racebum is offline   Reply With Quote
Old 10-25-2010, 06:33 PM   #10
I have been searching and trying to research caulk a bit, and it seems like a lot of people have had success using it. If you use a paintable kind that doesn't shrink, I don't see what a problem would be? The gap is small, and I won't have a problem spreading it to look clean and flat.
What is the name of the caulk that you recommend?
Old 10-25-2010, 08:24 PM   #11
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
is one, dap dynaflex is another great product
Old 10-25-2010, 09:32 PM   #12
Old 10-28-2010, 09:43 AM   #13
It looks like that is a discontinued product, they no longer have it in the store either.
How would this product do, or do you recommend a better one?
http://www.homedepot.com/Paint/h_d1/...atalogId=10053
Old 10-28-2010, 04:50 PM   #14
it's hit and miss if the ones that aren't labeled paintable actually can be. grab dap dyanflex 230, you can't miss it on the caulk isle
Old 10-28-2010, 06:08 PM   #15
There is that new GE Groov too, which is a combo of acrylic and silicone and says paintable. There was a couple that said they weren't paintable so I'll make sure to get one that is.
Drywall repair and matching texture question RickDel Drywall & Plaster 4 08-22-2010 10:52 AM
Wetted Drywall question Joe_Navy Drywall & Plaster 6 04-09-2009 09:09 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Drywall question Not Sure Building & Construction 6 08-27-2006 03:05 PM
Easy Drywall Question hohandy Building & Construction 10 12-16-2005 12:18 AM
