Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 06-20-2008, 11:05 PM   #1
Post
Drywall Problem
I have a problem with the newer plastic corner beading. I have a 45 degree corner beading made of plastic which has seperated from the wall along with other seperation of paper. My question is how to handle this repair? Should it be removed completly or just to the area of seperation and then be replaced with meash fiberglass tape?
charlie C is offline   Reply With Quote
Old 06-21-2008, 08:57 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Drywall Problem
It can sometimes be re-applied.
Examples: Adhesive spray, use blue masking tape to hold it in place until the adhesive sets. Then re-coat as needed..
- Build Well -
Old 06-21-2008, 08:25 PM   #3
Drywall Problem
i'd take it out, screw on the metal corner piece, then skim durabond over it, then two coats of joint compound, then repaint.
wombosi is offline   Reply With Quote
Old 06-21-2008, 09:31 PM   #4
Drywall Problem
The problem with me trying to use a metal beading, is there is no backing support on the back of the drywall at the 45 degree corner. can the metal beading be put in place with liquid nail? Or maybe just using a meash tape on the 45 degree corner? Thanks to all for your help, I like this idea of bouncing ideas around and getting many different idea. THANKS
Old 06-21-2008, 09:38 PM   #5
Drywall Problem
hm, i may not be an expert on drywall, but without a backing for the corner, the corner bead seams a bit redundant.
to do this right, you really need to strip the drywall entirely off of that corner, put in some nailer blocks as needed, then screw on new drywall.
you're getting into a mess here, with a lot more spackling, sanding, painting, etc... but then you'll have a strong corner.
i realized after the insulation was blown in, that i had neglected nailers in the corners, so i went back, took some foam out, and screwed in 2X2 strips where needed. then all seams are fiberglass taped and triple skimmed. larger cracks were durabonded.
you might get away with just fiberglass tape in this corner spot, if it's small. but i would definitely use durabond right over the tape, and go wide with it, maybe an 8-12" blade. get it very clean and flush, because it's basically not sandable when it cures.
good luck man.
Old 06-21-2008, 09:44 PM   #6
Drywall Problem
This is a 10 inch section on an eight foot wall, so I am thinking cut out the plastic and use the mesh tape and apply the mud, sand and repaint. Then get the heck out of Dodge. Thanks
Old 06-21-2008, 10:42 PM   #7
Drywall Problem
If it wuz me, I would just glue that corner back on with some white wood glue.
Just dip a pipe cleaner into white wood glue and work it around under the plastic corner bead to spread glue on both surfaces to be bonded.
Then just lean something (like a step ladder) against that corner to hold the corner bead in contact with the drywall while the glue sets up.
Then fix the drywall joint compound up as necessary, sand smooth, prime and paint.
Nestor_Kelebay is offline   Reply With Quote
Old 06-21-2008, 11:36 PM   #8
Moderator
Termite's Avatar
Drywall Problem
The corner bead is failing because it is not properly attached. If you don't have wood backing behind the joint, you've got a weak joint. Corner bead is a finish only, and can't "bond" the corner. Personally, I think gluing it is a band aid fix (at best) for a bigger problem. The corner needs to be assembled properly or it will be a constant maintenance issue.
Old 06-22-2008, 07:12 AM   #9
BUILDER / REMODELING CONT
buletbob's Avatar
Drywall Problem
I agree you need the backing. if you have kids banging the corner with there toys you will back again with another repair.
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Big problem with screwing a bracket to drywall bobman0330 General Discussion 4 11-06-2007 02:35 PM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 08:24 AM
Drywall problem LEudaly Building & Construction 1 05-07-2006 02:57 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
