Drywall Priming - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-30-2010, 07:13 PM   #1
drywall priming
how many coats for drywall primer
tookie43 is offline   Reply With Quote
Old 07-30-2010, 10:49 PM   #2
Registered User
Rewards Points: 5,514
Is this a trick question............. Two coats, one before the water based texture, and one after it. Three or more if using Hd or Lws paint. http://www.gypsum.org/pdf/GA-216-07.pdf
Be safe, Gary
Old 07-31-2010, 03:46 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 388
I have always used this with good results
http://www.duron.com/products/produc...t=3&lineid=393
chrisn is online now   Reply With Quote
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
drywall and priming baum Drywall & Plaster 2 11-13-2009 04:00 PM
Priming new drywall Dinger Drywall & Plaster 3 06-08-2009 12:11 PM
any problem with priming drywall before tape and mud goes on? nonDIYer Drywall & Plaster 2 12-21-2008 10:17 PM
