Drywall And Priming - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-12-2009, 01:56 PM   #1
drywall and priming
So i am almost to the point where the walls look smooth. I took a bright shop light and aimed it at the wall. i was wondering is there a certain primer i should use for a first coat that tends to sands better if i still happen to have any spots i missed? kind of like a sandable primer one may use in the automotive industry.
baum is offline   Reply With Quote
Old 11-12-2009, 03:24 PM   #2
Remodeling Contractor
nope. Use a PVA primer to seal new or patched drywall. Then you will need to patch the areas that will now be noticed. We do this all the time. Just recoat and sand the new patched areas. Be sure to prime these areas again of the paint will flash and be a different gloss than the rest of the wall.
Old 11-13-2009, 05:00 PM   #3
Drywall contractor
Rewards Points: 1,070
Bob's absolutely correct.......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 64 12-12-2014 05:15 PM
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 09:00 AM
painting old unpainted drywall snsaction@aol.c Drywall & Plaster 1 07-29-2009 01:57 PM
Priming new drywall Dinger Drywall & Plaster 3 06-08-2009 01:11 PM
any problem with priming drywall before tape and mud goes on? nonDIYer Drywall & Plaster 2 12-21-2008 11:17 PM
