Drywall Primer And Tape Showing Through - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 04:28 PM   #1
Drywall primer and tape showing through
Sanded it down like I'm suppose to and it looked fine but after I primed the wall and I can see the tape line is there anyway to fix this easily?
Arttart is offline   Reply With Quote
Old 09-15-2011, 05:32 PM   #2
It's really hard to say...Are you seeing the actual parallel lines of the tape, or the lines of the sanded down joint compound? If the former, then you did not properly apply enough joint compound. If you did all the coats properly, including the right amount of primer on the walls, then your finish coat should cover it just fine. A more complete description of the steps you used will probably allow folks to give you a more accurate answer.
1910NE is offline   Reply With Quote
Old 09-15-2011, 05:35 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The lines you are seeing are depressed...is that correct?
Old 09-17-2011, 05:39 PM   #4
Drywall contractor
Rewards Points: 1,070
Sounds like it needs another coat of mud....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 02-09-2012, 12:36 PM   #5
retired union carpenter
Send a message via Yahoo to coupe
this is an old thread, the OP has probably moved on? only one post, never a follow up.
its quite normal to see taped and finished areas after priming/painting. as the primer/paint soaks into different materials and dries in stages. when all is completely dry it was most likely fine.
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 08-14-2012, 11:56 PM   #6
what about screw holes? my screw holes were flat before priming now i can see the depressions; not all of them but quite a few.
Also, I'm having the tape problem too....I just primed and I can see a few of the tape outline showing through the primer. I did apply three coats sanded them down and they were smooth, could not see the tape at all but now i can see them. I was thinking of skim coating over the primer to hide them or would it be advisable to just paint and it will be all okay?
aigsrone is offline   Reply With Quote
Old 08-15-2012, 03:07 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
1)yes
2) no
The Following User Says Thank You to chrisn For This Useful Post:
aigsrone (08-15-2012)
Old 08-15-2012, 09:25 AM   #8
I'm guessing the same for the screw holes.
I'm baffled why this happened. I meticulously went over all seams and screw holes and before primer they were perfect. but not so after priming.
Old 08-15-2012, 03:53 PM   #9
chrisn's Avatar
Rewards Points: 394
1) yes, the holes will shrink, they always need 2 coats, at least
Drywall Tape cougar01 Drywall & Plaster 7 04-06-2011 06:09 PM
Primer on drywall kaytaycourtney Painting 1 10-03-2010 06:29 PM
primer lifts a bit of drywall mud rtoni Building & Construction 0 04-16-2010 03:36 PM
peeled primer (left the blue tape on too long) tjmack Painting 2 02-25-2010 12:16 PM
Sanding drywall primer and a few crack repairs n0c7 Drywall & Plaster 4 06-09-2008 02:31 AM
