Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-03-2010, 04:12 PM   #1
Drywall or plaster wall
How do I know whether the existing wall is drywall or plaster ?
I have a wall which I want to extend by removing the door in the middle of that wall. So basiclly, once I know what type of wall it is, I would like to add a wall in the place of door and also extend the wall for another one feet in the end.. Is that possible ?
I am just thinking of not to demolish the whole wall to rebuild again.
cprao is offline   Reply With Quote
Old 02-03-2010, 04:53 PM   #2
if you know the differance.. remove a switch or recepticl cover plate and look... it you don't know... do same and take a picture and post it..
Big Bob is offline   Reply With Quote
Replacing plaster with drywall secutanudu Drywall & Plaster 14 11-15-2009 12:44 PM
Repair drywall behind mirrored wall that were removed Donna34655 Drywall & Plaster 2 05-10-2009 05:42 AM
drywall on crooked wall drywall_trouble Drywall & Plaster 2 02-23-2009 09:39 PM
Plaster and Lathe walls- covering with drywall Jrr1099 Building & Construction 4 03-24-2008 03:20 PM
Plaster on drywall? bofusmosby Carpentry 7 03-06-2008 08:30 AM
