Drywall-plaster Corner - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-13-2012, 08:33 PM   #1
Rewards Points: 1,062
drywall-plaster corner
How do I mud/tape or join a corner on whose one side is drywall and on the other is plaster?
As can be seen in the attachment, left is plaster, right is drywall.
Old 07-13-2012, 08:57 PM   #2
DIY staff
Rewards Points: 7,174
You can use paper just like any other inside corner--or spend a bit more and use Straight Flex--
That is a heavy ,stiff material and will make the new joint easier to keep straight ==
amakarevic (07-13-2012)
Old 07-13-2012, 09:33 PM   #3
ultra flex, has many other names, or double tape it float the hell out of it
bf514921 is offline   Reply With Quote
The Following User Says Thank You to bf514921 For This Useful Post:
Venitian plaster faux painting using drywall compound? crankcase Painting 3 02-18-2011 07:51 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 09:28 AM
Plaster ceiling and drywall desrtrat Drywall & Plaster 13 10-08-2008 07:20 AM
Joining drywall and plaster pete1972 General DIY Discussions 5 10-28-2006 05:08 PM
