Drywall Or Plaster - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 06:35 PM   #1
Drywall or plaster
I'm a new homeowner and I'm trying to determine whether the walls in my house are drywall or plaster. The house was built in the 1950's. I have attached two photos. The first is a hole on one of the walls that shows layers of the material used. That is on the inside of an exterior wall. The 2nd photo is a different wall that separates two rooms. There is a opening in a build-in bookcase and I was able to take a photo of the wall from the inside. There are no laths but I have read that laths were only used with older plaster. Also that particular wall "feels" different when I knock on it compared to other walls in the house, including the one in the 1st photo (more hollow sound and does not feel as strong). I'm not an expert by any means and after reading a few articles I'm still not sure. I would appreciate your help!
Manos is offline   Reply With Quote
Old 08-21-2011, 07:32 PM   #2
Old School
Willie T's Avatar
My vote is for plaster.
Willie T
Old 08-21-2011, 07:40 PM   #3
DIY staff
Rewards Points: 7,174
Yep--plaster over gypsum lath
Old 08-22-2011, 10:20 AM   #4
Thank you!
Old 08-22-2011, 04:58 PM   #5
Drywall contractor
Rewards Points: 1,070
Plaster.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is online now   Reply With Quote
How do you intersect drywall (or in my case plaster) into tile on the same plane? Proby Kitchen & Bath Remodeling 5 08-02-2010 06:51 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 06:05 PM
Can you adhere drywall to plaster? whiskeykid Drywall & Plaster 9 08-15-2008 08:42 AM
Joining drywall and plaster pete1972 General DIY Discussions 5 10-28-2006 06:08 PM
