Drywall And Pipes - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-05-2011, 08:57 AM   #1
Drywall and pipes
I am prepping for my drywall of my basement. I was looking around the room and noticed that two of my drain pipes from upstairs are outside the framing. I noticed if I leaned on them they can be pushed back enough. My question is there any tips to pull them back to the cement wall? Any tips or ideas would be great.
mort5029 is offline   Reply With Quote
Old 01-05-2011, 09:33 AM   #2
Stay-at-home GC
ABS, Cast Iron or other? How far away is the cement wall? How do you feel about cleaning up poop?
typically not a good idea to force them somewhere they don't want to go as it can screw up your slope in other parts of the system or break fitting connections.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 01-05-2011, 10:42 AM   #3
Its ABS and there is room to just pull it back a couple inches so the drywall dosent hit it.
Old 01-05-2011, 11:25 AM   #4
Is the pipe level vertically when it just hangs there without you applying pressure? The reason I ask is because if you're taking it out of level by moving it back to be behind the studs, then undue pressure is being applied to the ABS joints, which in the case of drain pipes, will possibly eventually cause them to leak.
My suggestion is fur the studs out on the wall(s) where they stick out to avoid stressing the joints. They should have been run correctly in the first place (my guess is they weren't), but I guess you have to work with what you've got.
If your heart is set moving the pipes back then use some all around steel strapping to hold the pipes back.
Good luck!
VIPlumber is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Removing Drywall for Repairs BJH Drywall & Plaster 22 01-29-2011 02:22 AM
How to drywall wall with HVAC trunk and pipe penetrations daphilli Drywall & Plaster 3 09-27-2010 02:15 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 08:10 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 08:15 PM
