Drywall Patch Over Pocket Door - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-25-2008, 11:10 AM   #1
drywall patch over pocket door
I'm trying to patch a hole where a towel rod was pulled off wall over a pocket door. The towel rod needs to be reinstalled on the patched area. Any ideas for a very thin reinforcement behind the patch? Thanks.
kninja1211 is offline   Reply With Quote
Old 06-25-2008, 11:20 AM   #2
You should be able to put a piece of 1/2" plywood or such behind it easily. Find somebody with small hands to hold it in place for you through the end of the pocket door recess.
Screw it with 1" screws, patch, then screw the towel rack through the drywall into the plywood.
Armitage is offline   Reply With Quote
Old 06-25-2008, 11:30 AM   #3
Thanks. I,ll give that a try. Now I just need to find someone with small hands.
Old 06-25-2008, 11:34 PM   #4
Registered User
Termite's Avatar
You can cut the holes a little bigger and insert strips of plywood or thin wood that are a few inches wider than the holes. You can use a screw for a handle. Screw through the existing sheetrock on each side of the holes to secure the plywood to the back of the rock. Then you can apply a patch piece of rock right to the strips of plywood with a couple screws. Tape, mud, sand, and you're good to go.
Just be sure to use short screws! I once nailed my pocket door in the open position by forgetting that it was there when I was running base during a remodel of my living room. The 2" nails I was shooting weren't the thing to use on the pocket wall. Doh!!!
Pocket Door Installation Randell Tarin Building & Construction 10 03-30-2008 05:30 PM
Pocket door and tall floor...oh my wem Remodeling 3 03-24-2008 05:45 PM
Door jam between rooms is drywall dsanders55 Flooring 2 03-05-2008 05:35 PM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
