Drywall Patch In One Day - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-20-2013, 07:02 PM   #1
Rewards Points: 4,796
Drywall patch in one day
Sorry, this is a question, not an answer
Is there a way to do a serious patch (with paper tape) and still finish it in one 8 hour day (including painting) with sanding on the final coat? I'm hoping someone knows some new technology or technique. I can use setting compound to get on 3 coats in a day, but it will never dry enough to sand that last coat. Of course I could be perfect and not sand, and I suppose wet sponge sanding might work, but how about painting over that wet patch? I can't imagine the paint would adhere well to wet compound.
jeffnc is offline   Reply With Quote
Old 08-20-2013, 07:51 PM   #2
DIY staff
Rewards Points: 7,174
If you get an answer,I'm all ears---
I've done a lot of patches in a day also--but the mud is to wet to paint---
Gymschu (08-20-2013)
Old 08-20-2013, 08:54 PM   #3
Gymschu's Avatar
Rewards Points: 682
That would be the HOLY GRAIL answer of Drywall repair, JeffNC.......I would like to know as well. There's just those times when it has to be done in a day.
Gymschu is online now   Reply With Quote
Old 08-21-2013, 01:22 AM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 320
no
Old 08-21-2013, 06:54 AM   #5
Rewards Points: 5,974
Ok here goes. Get a piece of plywood about 2'x2' I use a sink cutout the formica on it makes a really nice surface. Now take a good sized scoop of mud and plop in on the ply. take your small drywall knife and go around the inside, kind of making a donut looking shape or a volcano, go clear down to the surface of the ply. Now put about 1/2" to 3/4" of water in this valley. Now take Plaster of Paris and put enough to cover the water (you will need to do it a couple times to get the feel for how much to use). Remember just cover the water not the mud round the edge. Let this set a minute so the Plaster of paris absorbs all the water, it will turn gray. Now cut this in 4 sections, like a pie, pull one section away from the rest with your knife and mix the plaster and compound really well. You now have about 10 minutes to apply. This compound will dry very hard, buy the time you go scrap the excess from your tools this will be dry. You can go back to your donut pull section 2 of your pie mix it and repeat. Have used this for several years. I always used a thin coat of ultra lite weight mud for a top coat just for the ease of sanding. There is a video on you tube showing this I will try to put a link up this evening.
Old 08-21-2013, 08:49 AM   #6
Old School
Willie T's Avatar
I've done mud on wood for fast drying, and I know I should be ashamed of myself. But I was young, and dumb. It does dry fast, but it is a faulty repair.
The trouble with what looks fine when you walk away is that wood dries over the years, and that nice, smooth coat of dried mud will eventually develop cracks, and maybe parts will even fall off the wall.
Willie T
Old 08-21-2013, 10:13 AM   #7
I've done a patch not requiring paper tape (e.g. filling in wall anchors and other smaller patches) and have been able to get on 3 coats and drying them with a hair dryer (high speed, low heat, and just leave it there hanging from a ladder hook or something, aimed at the wall.) That can work well. I just can't see that drying out a full patch with paper tape and joints in less than 8 hours. I also don't like leaving the room with the dryer on. But now that I think about it, I do have a little room heater that I might try - it has an auto shutoff if it tips over. Similar to this one
http://www.lowes.com/pd_42722-47166-73610_0__
Old 08-21-2013, 03:17 PM   #8
OK guys I could not get the link on my laptop. But if you go on you tube to;
Laurier Desomeaux repair a hole with no sanding.
there are like 6 short videos if you can watch them all but at least watch #4 and # 5. I use this same method and it really works. If this doesn't work let me know and I will get on my other computer and download.
Old 08-21-2013, 03:27 PM   #9
Old 08-21-2013, 03:30 PM   #10
Thank you Jeff how did you do that.
Old 08-21-2013, 03:32 PM   #11
Well, technically he says "when you sand, you sand to blend, not to repair" (emphasis mine). So "no sanding" is a bit of an exaggeration there.
I do like the videos though, and his technique with the large trowel. I'm not sure what you gain here with using his blend over standard setting compound (I haven't had time to watch them all the way through, maybe I missed something.)
Having said that, I can see how you could get away with sanding only the outer edges of that patch. In that case, you could certainly dry those areas with a fan or hairdryer. You wouldn't need to dry or sand the whole thing.
The painting issue still remains - the center of the patch will be wet.
Old 08-21-2013, 03:34 PM   #12
Used your search terms, then just copied the URL of the first video. On the right I found the links to the next companion videos in order, and clicked on them and copied the URLs one by one
The Following User Says Thank You to jeffnc For This Useful Post:
ToolSeeker (08-21-2013)
Old 08-21-2013, 03:57 PM   #13
The advantage of the mix I have found to be it dries thoroughly all the way through unlike hot mud that just dries on top. And I like you can go back and get more without cleaning everything and mixing more. I have put on three coats 2 of the mix and a thin topcoat of lightweight, sanded, primed and painted in a day.
Also seems like this stuff is easier to work and sand than hot mud.
Old 08-21-2013, 04:23 PM   #14
Then I guess I'll have to give that a try....
Old 08-21-2013, 05:15 PM   #15
Too Short? Cut it Again!
I hope I am not missing something or reading wrong...
I have done winged patches with hot mud in a day easily. 5 minute mud sets up near instantly but can be a challenge for a novice to work with. Start with the 20. It comes in 5-120 minute as I remember. Do get the easy sand.
Of course it takes a little time to cut out and fit the drywall patches. You need to bring them out flush to the wall so you do not have to build up layers over them.
If the entire patch is a layer or two of mud, or using pre-mix tub mud, no way. I think you are asking for trouble for all the moisture to evaporate out, sand, prime and paint in a day. Even with 5 minute.
Flat drywall patch christina0806 Painting 22 02-01-2013 03:49 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Texturing drywall patch? Doug Crf Remodeling 4 09-21-2006 07:54 PM
