Drywall Paper Seperating At Baseboards - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-27-2012, 12:23 PM   #1
Drywall paper seperating at baseboards
How do you fix drywall paper seperating from the drywall?
The baseboardv we removed is the same size as the new baseboard.
jglende is offline   Reply With Quote
Old 04-27-2012, 12:39 PM   #2
Stay-at-home GC
When you pulled the baseboards off some of the paint adhered and pulled the paper off the drywall?
If its just the outer layer of paper you can skim over it with a coat of drywall compound. Use a razor to cut the loose flappy pieces back to solid paper.
If the gypsum core is showing embed a later of tape and do two coats.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 04-27-2012, 12:51 PM   #3
Rewards Points: 14,020
When removing any trim you always have to cut the paint line first with a razer knife.
Tags
baseboard , drywall , plaster
drywall over old plaster... lcann25 Remodeling 0 09-20-2010 11:53 PM
Rookie questions - drywall paper rips Eusibius2 Drywall & Plaster 13 08-14-2010 08:46 PM
sanding into paper on drywall patch joseph2293 Drywall & Plaster 11 02-23-2010 08:53 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Felt Paper and the Sun. Valley problems hartkem Roofing/Siding 1 07-22-2009 03:57 PM
