Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-08-2012, 02:11 PM   #1
Drywall paper ripped
Drywall Gurus
I need help and fairly quickly if you could.I have taken off the
4inch x 4inch tiles from around the fiberglass shower stall we have in our ensuite. I cut out the grout lines with a carbide tipped hand tool and used a chisel to remove the tiles.Unfortunately some of the first layer of gyproc (sheet rock) paper came off with the tile and left the brown paper exposed.Is it okay to put mud on top of that to level it out.The drywall is 4 inches wide under the tile and is intact from under the corner bead to where it ends before touching the flange of the shower stall.This all out side of the shower stall itself.
Thanks Fellas
scarrylarry
scarrylarry is offline   Reply With Quote
Old 04-08-2012, 02:28 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Skim over with a wide blade to get the best results.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
First-timer drywall install-LONG- Axhammer Drywall & Plaster 8 04-17-2011 10:02 AM
Rookie questions - drywall paper rips Eusibius2 Drywall & Plaster 13 08-14-2010 09:46 PM
sanding into paper on drywall patch joseph2293 Drywall & Plaster 11 02-23-2010 09:53 PM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Felt Paper and the Sun. Valley problems hartkem Roofing 1 07-22-2009 04:57 PM
