Drywall Paper Face Issue - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-23-2013, 12:25 AM   #1
Rewards Points: 351
Drywall paper face issue
I've been working on getting the upstairs of my house painted, patching nail pops, filling divots, sanding paint drips, ect... The one room had a really nasty patch on the ceiling so I figured I would fix that as well. Ended up finding that there wasn't a lot supporting the area and at one point there was a leak. I ended up pulling off a few layers of the paper facing while removing the patch. Do I need to cut this large portion out or can I paint it with a primer/sealer to keep what's left of the paper together?
My plan was to go into the attaic and add some 2x4s to secure the area. I think I'm going to have to cut a 3" channel and put some fresh drywall in as well at the joint since the existing drywall isn't in great shape.
I was also going to add some drywall screws to the field since there doesn't seem to be a lot of fasteners 1 every 24"
info2x is offline   Reply With Quote
Old 08-23-2013, 01:11 AM   #2
Rewards Points: 626
I would replace that and do it right. Sorry but that is just hack job. You need to do it correct.
Nailbags is offline   Reply With Quote
Old 08-23-2013, 05:42 AM   #3
automated tool pro
Rewards Points: 152
replace it
drywallfinisher is offline   Reply With Quote
Old 08-23-2013, 06:19 AM   #4
DIY staff
Rewards Points: 7,174
Time for new---------
Old 08-23-2013, 06:34 AM   #5
Rewards Points: 351
Ok... Wanted to avoid it if I could but if that's the right way so be it. Any good tips on how to make it look good? That's a 3x3.5' area and would essentially be but joints all the way around.
Old 08-23-2013, 06:42 AM   #6
DIY staff
Remove the unpainted area---to the center of the nearest joist--or to the edge of the joist and then add a nailing strip---
replace the sheet--use 20 minute easy sand to fill any big gaps (if you have any)
Use paper tape---use multipurpose (green lid) to set the paper--that mud contains glue and will bond the best---
use the same mud for the first coat or two (powdered Easy sand could be used instead but is more difficult for a novice)---then use Light Weight (blue lid) for the final top coat--it's soft and easier to sand than bag mud or multi purpose--
Old 08-23-2013, 06:54 AM   #7
Rewards Points: 4,796
Gardz is made for damaged drywall like that. However that's really too big a gap you have there to be filled in with tape and joint compound, so you might as well redo it.
jeffnc is offline   Reply With Quote
Old 08-23-2013, 08:11 AM   #8
Rewards Points: 13,446
Just going to have to end up with about a 12" wide tape seam to level it all out enough to not show.
Old 08-23-2013, 09:00 AM   #9
Rewards Points: 5,974
Just my opinion but some gardz, easy sand, paper tape, mud, would be a lot easier than replacing those 2 sheets of dry wall.
Old 08-23-2013, 01:06 PM   #10
Rewards Points: 351
That was my original thought
Ok
That's why I was thinking of cutting a channel down the center of the gap and putting a strip of drywall in there. The water damage has not been kind to the drywall, nor has my hacking away at the joint.
Interesting comments on the green lid stuff. I've been using blue lid for most of my repairs since they are minor. Thanks.
Old 08-23-2013, 06:06 PM   #11
Rewards Points: 351
Ok so now that I'm home I poked around a little more. Gardz is out. I wanted to measure the thickness of the drywall so I could pick up a sheet if I decided that was the route I wanted to go. The paper on the top of the drywall was done and a substantial chunk fell out of the ceiling that if I were a betting man probably had some mold on it. The upper surface of gypsum was exposed and had clearly seen better days. Looks like I'll be replacing the section.
Old 08-23-2013, 06:14 PM   #12
DIY staff
It's not that big of a job---because you do not have tapered edges---plan to feather that tape joint out about 20 to 24 inches----be patient---thin coats----thin----
Old 08-23-2013, 06:28 PM   #13
Rewards Points: 351
Yeah I learned the thin lesson while working in the laundry room. Would 1/2" drywall taper to about 3/8"?
I know I'm not getting tapered drywall for this project but I think what was there was tapered and why I got two different measurements.
Old 08-23-2013, 06:34 PM   #14
DIY staff
The taper is about 3/8----back in the 1950s they did use 3/8 drywall on economy work---cut out a square and really check it--I do not know if it is still available-----
Old 08-23-2013, 06:38 PM   #15
Rewards Points: 351
I thought 3/8" was a little thin so I did take out a chunk about a foot off the edge and it came in at 7/16". Considering that the paper mostly gone on both sides I think I"m good with 1/2"
The Following User Says Thank You to info2x For This Useful Post:
oh'mike (08-23-2013)
Drywall Anchor Issue tcharleschapman Drywall & Plaster 9 07-18-2013 07:46 AM
Paint peeling along with drywall paper Steveski54 Drywall & Plaster 3 03-03-2013 09:35 PM
Crinkles on full wall drywall seams. Big issue? bteudt Drywall & Plaster 9 06-30-2010 04:16 PM
Furnace Issue After Sanding Drywall libero99 Drywall & Plaster 8 01-10-2009 09:08 PM
removed wallpaper drywall paper face ripped right off! flashme18 Painting 7 07-23-2007 10:07 PM
