Drywall Painting - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-16-2012, 01:03 PM   #1
drywall painting
my contractor put a butterswirl of joint compound on newly done drywall and he didnt cover the entrire drywall. I feel this is cutting corners. Should they entirely cover the drywall to cover any imperfections?
armsaround is offline   Reply With Quote
Old 02-16-2012, 01:05 PM   #2
my contractor put a swirl of joint compound on newly done drywall. He didnt cover the entire drywall, exposing some of the gray fabricy drywall material. Shouldnt you cover or skim all the drywall before painting?? sue
Old 02-17-2012, 11:26 PM   #3
Rewards Points: 154
I'd sue too.
I should come to this subforum more often
Did he just cover the screw heads? This is normal, no need to skim coat the entire wall unless there is something wrong with the surface such as all nicked and gouged up due to removing stubborn wallpaper or something.
pete0403 is offline   Reply With Quote
Old 02-19-2012, 05:37 PM   #4
retired union carpenter
Send a message via Yahoo to coupe
Originally Posted by arms around View Post
my contractor put a butter swirl of joint compound on newly done drywall and he didn't cover the entire drywall. I feel this is cutting corners. Should they entirely cover the drywall to cover any imperfections?
I have no idea what you mean by"butter swirl of joint compound" if this is new drywall install? the taper/finishers job is to coat and finish all nail/screws finish all joints,butts, corners and corner beads. if you wanted a plasterer's finish? you should have gotten a plasterer!
standard practice is 3 coats of compound over all joints nails/screws, inside and outside corners, and imperfections in the drywall that can be seen! talk to your contractor
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Painting new drywall Leanne1 Painting 12 02-05-2012 05:05 AM
drywall mud dry time before painting dmillar Painting 5 01-26-2012 01:52 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 05:37 PM
painting over repaired areas on drywall sandymc Painting 3 08-22-2011 05:20 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
