Drywall + P&L Screws ? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 07-15-2012, 11:17 AM   #1
Rewards Points: 166
drywall + P&L screws ?
1/2" drywall over P&L ceiling. i bought a box of 2" screws. by just "eyeballing" them. it looks like i will have just under 1" into the joist. will this be enough ?
Fix'n it is offline   Reply With Quote
Old 07-15-2012, 11:24 AM   #2
Rewards Points: 12,878
Not a great plan, I would have removed the plaster first so you can see where the joist are and it would lay flater.
If your going to do it your way I also would use drywall adhesive and longer screws.
Old 07-15-2012, 09:11 PM   #3
Rewards Points: 166
yeah, i know. but i can't take the p&l off the ceiling = no time. i have WAY TOO MUCH on my plate as it is.
i used the 2" screws, and they worked fine. i went in the attic and drilled holes on the north side of the joists. so my screws hit the joists. sides, the few times i missed a joist, i could easily tell and put one next to it.
Old 07-26-2012, 11:35 AM   #4
Drywall contractor
Rewards Points: 1,070
1" penetration into the joist is fine. I would have used adhesive too as mentioned above....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Drywall Screws Rusting? rick112 Drywall & Plaster 17 03-29-2011 11:57 AM
drywall over old plaster... lcann25 Remodeling 0 09-21-2010 12:53 AM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 01:24 AM
Attach Drywall through plywood HooKooDooKu Drywall & Plaster 2 01-20-2010 11:05 PM
